Ask a Professional Detailer...
Rating: Thread Rating: 10 votes, 5.00 average.
  #2131
Old 11-25-2015, 01:10 PM
Detailed Image's Avatar
You've got the basics down, but I highly recommend using a dual action polisher rather than a rotary machine.... especially if this is your first time using a machine on your car.
Dual action polishers are almost foolproof. They are very safe, and the chances of burning through your clear are slim to none. Rotary machines, on the other hand, are very dangerous in untrained hands. It just takes a second to burn through the paint and cause damage that must be repainted.
Right now the Porter Cable 7424XP Dual Action Polisher is on sale for just $109. That is a lot cheaper than having to repaint a panel, and the results will be excellent as there is no chance of creating holograms in the paint with a DA machine like you can with a rotary. Add in a 5" backing plate and some pads, and you're good to go.
Let me know if you have any other questions.
  #2132
Old 06-10-2016, 07:19 PM
DRG35R's Avatar
G35 Coupe "Sport Package"
have a 2015 BMW 3 series sport wagon. a bottle of Pine Sol spilled in the rear hatch. luckily I have a hatch liner that caught most of the spill, but some splashed up onto the seat backs that were up. the seat backs have carpet on them and they got soaked pretty good. got as much out with dry towels with weights placed on them. was not going to attempt the complete clean up myself, so took to my favorite detail shop. they used an extractor on the area and also ran on ozone machine overnight. I also changed out the cabin filter, but you can still smell it. it has only been a week, but I need this smell gone. I have been keeping windows down as much as possible and have also put baking soda on a cookie sheet in the back hatch in hopes of absorbing some of the strong pine scent. any other suggestions would be appreciated. thanks in advance.
  #2133
Old 06-14-2016, 09:31 AM
Sounds like the extractor and ozone treatment was not done properly. If the seats were extracted completely, there would be no chemical left in the fibers.
You may also contact Simple Green to see what they recommend to neutralize their chemicals. I believe simple green is an alkaline cleaner (pH well above 7), so you may need something acidic like vinegar to neutralize it... but I would consult with them on that before spraying vinegar everywhere
  #2134
Old 06-15-2016, 05:05 AM
DRG35R's Avatar
my thoughts exactly on the detail/cleaning job. been going to this shop since 2005, but they have grown very large with all of their car dealership contracts. feel like they have lost the personal touch required of detailing. not much choice in my area, but may have to look around to find better.
did you mean Pine Sol versus Simple Green?
  #2135
Old 06-15-2016, 09:04 AM
Ha, oops... idk why I jumped to Simple Green. Sometimes my brain doesn't work... but yeah, same situation. You may reach out to Pine Sol to see what they recommend to neutarlize their chemical.
  #2136
Old 07-11-2016, 03:32 PM
ibg's Avatar
ibg
ibg is offline
I have an 04 black sedan on which i keep getting water spots due to the sprinklers
Every time i get these water spots i take it to a detailer and have them remove them since i haven't been able to figure out a way to do so myself and i am afraid of damaging the paint.
i have seen many posts about using water mixed with vinegar but that would require polishing/waxing afterwards
I was wondering if there is anything else besides water/vinegar mix that i could use to get this done?
Also every time i wash my car I wait for it to be cool and in the shade i try to use the best car soap i can find yet i also soak the car with a good amount of water before i start washing the car. I soap the car and quickly rinse it off . BUT i still keep getting soap residue marks on the car like if i never washed the car... I like to spend time on my car not having to take it to car washes .. any help on this ?
Thanks in advance
  #2137
Old 07-12-2016, 08:12 AM
Hard water can cause some serious damage to paint... you need to avoid the sprinkler water, and that will solve your problem for you.
Please read these articles on water spots....
Understanding Water Spots & How to Avoid Them by Zach McGovern
Removing Water Spots by Zach McGovern
I wash a lot of cars... and soap residue is not something I have ever had an issue with. Make sure you are following the manufacturer recommendations for diluting the soap, and simply rinse the soapy water off of the car immediately after washing a section of the car. If the vehicle is cool, you should not be having issues.
Hope that helps!
-Zach
  #2138
Old 07-12-2016, 09:59 PM
ibg's Avatar
ibg
ibg is offline
i was going to try doing the water/vinegar that many people have stated before but i decided to try 3D ERASER which is meant for water spots .. it did a so so job but to be fair it was my first try with it and it might have been some user error i am going to give it one more try...
Hope that helps!
-Zach
honestly i have tried many times to do as you say but i guess i will have to come out with my measuring cup just to get it precise and avoid keep getting soap smudges.
also do you thing the top of my car can be fixed with maybe a polish/wax or something of that nature or is it going to require a paint job ?
  #2139
Old 07-13-2016, 04:29 AM
jcritical's Avatar
My car is lowered so I am forced to park outside. The car is being exposed to sunlight most of the year. What can I do to reduce the likelihood of clearcoat fading/paint damage?
  #2140
Old 07-13-2016, 09:54 AM
As I explain in the articles I posted in my original response to you, the water spots may not be removable with a chemical. If they have begun to etch into the clear coat, they will need to be removed with abrasive compounds and/or polishes.
Again, avoiding the sources of hard water will be MUCH easier than dealing with removing the water stains over and over.
It is hard to tell from the photo, but that appears to be some defect that will require body work, not detailing. More detailed photo would help.
My car is lowered, but I still let it in the garage
You're going to want to keep maximum UV protection on the car at all time, make sure to keep it clean, and remove any harmful contaminants ASAP.
Protection comes in a variety of forms - waxes, sealants, and nano coatings. All have their pros and cons, so find the best product that fits your needs.
Wash the car regularly to remove loose dirt and contamination using proper washing & drying technique.
How To Properly Wash and Dry a Car by Todd Cooperider
Utilize a clay bar and/or various chemicals to remove bonded contamination that will set on the surface of the vehicle over time.
Explaining the Decontamination Process (Part 1) by Zach McGovern
Explaining the Decontamination Process (Part 2) by Zach McGovern
Let me know if you've got any other questions
-Zach
  #2141
Old 07-13-2016, 10:19 PM
jcritical's Avatar
You mentioned to keep it as clean as possible. How does a layer of dust damage it?
  #2142
Old 07-14-2016, 07:41 AM
Dust, not a big deal... but if you drive the car regularly, there is certainly more than just dust accumulating on the paint. There are all sorts of chemicals and what not on the roads that can end up on your car, also there are plenty of airborne contaminates that will settle on your vehicle as well. I recommend all my customers wash their vehicles at least every other week to help keep them clean.
-Zach
  #2143
Old 03-02-2017, 06:53 PM
OfromDa860's Avatar
Hello g35 forum! I just picked up an 04 g35 coupe from a dealer trade in as in "as is' vehicle... There's a lot of what looks like duct tape residue on the doors and various spots. What would you recommend on removing without damaging paint? Thanks in advance!
  #2144
Old 03-03-2017, 06:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Goo Gone or Goof Off have always worked well for me.
  #2145
Old 04-24-2018, 01:49 PM
sonors's Avatar
quick(er) paint sealant
I want to apply a sealant to my car but prefer not to have to wait overnight before driving it while the product cures. Are there any sealants that enable you to use the vehicle shortly after applying/removing?
seagrasser
05-03-2022 09:43 AM
sales@czp
Suspension-Vendor
26
11-06-2017 03:04 PM
zoop425
03-29-2016 05:51 PM
Oregon13
Audio/Video/Electronics
03-01-2016 12:06 AM
cmesidewayz
09-29-2015 09:28 PM
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
Quick Reply: Ask a Professional Detailer...
