| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
^^^+1 - whs
thank you.
how about making a How-to section? good write up w/ flicks. |
I am a complete novice but I followed your instructions on how to fix a scratch on the hood of my black G and it worked 95%. I don't know how to proceed and I was hoping for some direction.
I used a matching pen paint with the toothpick. (Very patiently over two days.) I ended up with the blob. I left it for a week. I did everything you said. I bought unigrit 2500, I soaked it overnight, I sanded carefully in one direction with regular soapy water, I got the blob level with the paint (I think.) I wiped it away with alcohol water. I crapped myself! I then used Pinnacle Fine Swirl remover XMT with the PC just like you said (3 and then 6) with an orange pad. (I spent so much on buying the PC and the products it came with from Autogeek, I didn't want to buy more and it sounded like it was the same as you were recommending.) It worked very well to remove all the scratching from the sandpaper. In fact up to there it was much easier than I expected. The problem is that I can still see the marring. It looks like an very slight lump in the paint when you see it in the reflection and it has sort of white flecks in it. I repeated the process at least ten times and it got much better but it is still there. It looks to me like the problem is that it is indented where the scratch was and not converse or above the rest of the paint. I got nervous and stopped. Maybe the paint dried with bubbles in it and those are now small holes in the scar? One of my other questions is how many times can I keep going over it with the PC. Is there a point at which you are just screwing up the paint? Your instructions were brilliant! I have confidence that I could do it again following them and do even better. The question is should I? Is there a way to remove the paint added or sand down what I have done and start again? Should I? Any help appreciated. |
Maybe use some clear coat and build it up to the right level.
Make this thread a sticky please.
__________________
FUNCTIONTUNED:POWER |
Quote:
Awesome DIY Kevin, I can't believe I missed this thread for 2 years. |
Thanks. Will the clear coat hide the white flecks in the scratch? And how many times can you sand, polish, etc. before it is a problem for the paint?
Picus, any advice? Please ..... |
Quote:
__________________
I really want to do this but Im scared haha. My car is BS though...might not be that easy to see mistakes.
__________________
JDM Brown G35c 6mt/Drilled Holes in my exhaust/Cut my springs/AC duct Intake/Dremeled lines in my rotors/Paper air filter/ebay clutch/AC delco/Raybestos/BONDO/Duct Tape/Electrical tape/Aluminum foil/Song playing in car- http://www.youtube.com/watch?v=ArSVUUiLGZ0 |
Quote:
Ha better late than never. This is an excellent article; was really suprised when I found it on Autopia and not G35Driver (didn't know it was buried
thanks for the thread man..Great work
Quote:
__________________
Obsidian Black// Volk // SPC // Fujita // Tanabe //
Quote:
__________________
http://gtaindetail.com |
#30
I recently purchased an 06 Coupe and it has a 1/10 of an inch chip in the paint on the fender and it has rust on it. What is the best way to clean the rust off? If the best way is to wet sand it do I just try to wet sand in the chip pit or feather it out and with what grit sand paper?
After I apply the touch-up paint and wet sand it smooth using 2000-3000 grit do I need to buff it smooth before I clear it? Also what kind of clear coat should I use? Just regular auto krylon clear? I am assuming after i clear I need to wet sand again right? |
| Tags |
| 210, autopia, bumper, chipped, chips, directions, duplicolor, fixing, megs, paint, plastic, rear, reviews, rock, scratch, touch, wetsand |
| Thread Tools | |
| Display Modes | Rate This Thread |
