Leaking oil in spark plug
on
^ engine cover is something else, u replace the valve cover
By buddy is selling his spare set of valve covers in the market place
https://g35driver.com/forums/engine-...ve-covers.html
on
G35man04 thanks for the info. I may need to hit you up on this. I pulled coil pack 6 as well and it was leaking oil. So, I think I need to order that laundry list of parts that is on sticky to replace both valve covers. Does anyone know if this would cause increased fuel consumption and rough idle?
I've had oil in the spark plug wells for years. Never knew until I changed my own plugs a couple years ago. I immediately got on driver and searched until my search button about fell off and iirc the end result that I found was that it was relatively harmless. I decided at the time it wasn't worth the money to fix it so I left it alone.
It's been about 10k miles now and I am due to change my plugs again (copper NGK 1-step colder for boost) so I will see what it looks like now. It's never been an issue as far as oil consumption (or oil loss) for me. When I think about it, I am more prone to leaks with higher intake pressure and it still hasn't posed any issues for me.
I do an oil analysis every oil change (which are about 1 year apart) and have never had anything but good results (using only Mobil1 0W-40 and Mobil filter).
