Transgo @ the track
Transgo @ the track
I recently added a transgo shift kit to my stillen VB. The shifts are night and day compared to the Stillen. I can chirp the tires on the 1-2 shift and sometimes on the 2-3 in a auto.
Well granted these are not my normally faster runs due to the high DA (temps and humidity). The best I could do was 14.2@101 my fastest at this same track is 13.4@101.
The video is to show the shift kit in action at the track. Enjoy and more videos to come soon when it gets cooler.
I raced a new challenger R/T and probably would of beat him or gotten closer if I had traction. I was on street tires and he was on DRs.
What track did you go to? I plan on moving to the owning mills area in the next few months.
Hopefully we can hit the track one day when I move to MD.
Mason-Dixon usually.......I actually didn't go because when I calculated the DA I just opted against it and went to the meet-up in Sterling.
Mason is ~600ft, but it is a bit cooler than other MD tracks. It isn't uncommon for the DA's to go negative in mid-late Oct.
You should see if you can borrow AJ's DR's.
I think so if you like to race from time to time or plan on going FI yes.
Here is a video before the upgrade with just the Stillen which shifts faster than stock, but not as quick or firm as the Transgo.
I shift at the same RPM between 6700-7k my rev limit is 7200.
