Revup 6MT hold 3rd gear at end of the 1/4?
For those of you that are close to stock, are you holding 3rd gear as you cross the line or grabbing 4th at the last second? I've dragged this car once and I'm pretty sure I was rowing to 4th right at the last photocell. Most posts on here claim that the factory tach is fibbing by +300 to 400RPM. If that's true, I'm almost thinking I could hold 3rd and cross the line with the tach showing 7300 or so. I realize answers to this question will vary depending on trap speed but I'm still curious what the consensus is.
4th gear is absolutely required. I don't have the gears plotted right in front of me, so I'm going off of memory here, but I'm pretty sure that given a 7200rpm fuel cut and a tire size of 26.3 inches, 3rd runs out at ~92mph.
So, theoretically, you could hang on to 3rd all the way till the end if you were racing at like 2500ft.
baker2795
09-02-2015 06:00 PM
Frostbite91
08-20-2015 07:20 PM
