MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > Motorsports > Drag
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 09-30-2009, 09:12 AM
00gts6speed's Avatar
you are supposed to
__________________
2004 Diamond Graphite Infiniti G35 Sedan 6MT Revised 350Z Suspension/New VQ @ 71k
Old 09-30-2009, 11:04 AM
on street tires, no you dont lower your tire pressures. on real race tires, yes.
__________________
FOR SALE460whp DD Non-Rev Vortech V-3 SI turnkey, 4" IC, UTEC, 600cc $4400 shipped
Old 09-30-2009, 11:37 AM
false...you want more sidewall flex at the drag strip no matter what tires you have
if you were autocrossing or road racing you would add more pressure so you would have less sidewall flex
__________________
Old 10-01-2009, 05:11 AM
My 60 foot times did not change at all when I lowered my pressure. I have tried 32psi, 25psi, 20psi, and 15psi, and there was virtually no difference. I now run with 30-32psi and get 2.1 60 foot times.
At best, it'll net a SLIGHTLY quicker 60 foot time, but idk... I only noticed a 0.01-0.03 difference with the lower tire pressure, and that could have been from heat or any number of variables.
__________________
03 BS Base Sedan 5AT Motordyne 1/2", Borla TD 14.23 @ 99.86, 2.15 60 foot, 1243 DA
Old 10-01-2009, 05:17 AM
^ interesting
i'll have to try myself as well.
__________________
2004 Coupe 6MT |Brembos|Greddy Evo2|JWT Pop Charger|OEM ZTube|Eibach Pro Kits|
Old 10-01-2009, 09:16 AM
every person ive ever talked to has said to drop your pressure into the mid-low 20s, 15 is too low for street tires
__________________
Old 10-01-2009, 10:19 AM
^ then i would go by what they say instead of what experienced drag racers do! Because we all know that street tires have flexible side walls, esp those 35-40 series tires we all are using. LOL!! Pass your BS on to other who dont know any bettter.
__________________
Old 10-01-2009, 10:32 AM
well 35-40 series tires suck *** for drag anyway...
im just talking about people who pulled great times in stock or near stock cars. also going to the track when its cold with summer tires is not the best idea
__________________
Old 10-01-2009, 01:38 PM
I run with 205/65/16's at the track.
Kuhmo Ecsta LX Planintums for $88 a piece from Tirerack
I also get no wheel spin off the line, and my best 60 foot is a 2.1.
I'm not trying to toot my horn, but I think street tires should not be messed with too much.
__________________
Old 10-01-2009, 02:11 PM
wow 65 profile...see thats why you have good times...everyone else is like YEAH BoI i gotz 20z why am i running 15s?..lol
how heavy are the rims?
maybe i will stick with my 15.4lb 17x8 koseis
__________________
Old 10-03-2009, 06:34 PM
I have no idea about the weight, but they were lighter than the OEM coupe 17's I had on at one point.
I would recommend keeping your rims.
__________________
Old 10-04-2009, 12:52 AM
yeah i think i am, i think the oem 17s are like 25-26lbs from what i read, so 15.6 lbs is like a 40lb unsprung weight redux
and the offset is pretty good at +35 also...just gonna have to deal with all the ballaz hating on my 17s..lol
__________________
Old 10-04-2009, 02:06 AM
2003 Nissan 350Z
6000rpm with a slight feathering of the clutch then full engagement. If the tires are hot and track prep is excellent I can foresee redline (7100rpm in my car) launches. I also run an OS Giken integrated clutch set-up.
Track ready:
On street tires I launch around 2800......but more throttle and clutch modulation is necessary to net the best 60's (I have pulled (2) 1.98's and about 392048209340923 2.0's).
__________________
03 Z Bolt-ons w/Osiris 282.5whp (dynojet) 13.24@106.98 FunctionTuned
Old 10-04-2009, 03:34 AM
Jairen's Avatar
DJ For Hire
I can't get better than a 2.200 on my OEM 19's with crappy Goodyear Eagle RS-A All Season's.
I've also messed around with tire pressures. Did me no good.
__________________
2005 Ivory Pearl 6MT Coupe Sport // Car Videos at http://www.youtube.com/MyRaceChannel
  #30
Old 10-04-2009, 06:44 PM
2003 Infiniti G35 Coupe
I once hit a 2.0 60' with my 5AT that had 3.9 gears w/ Goodyear Eagle F1 tires 285/40/19.
For an MT on an 05 revup with normal street tires I hold it at 3K RPMS slip out the clutch.. As soon is it grabs and car starts rolling and quickly fully release the clutch and floor it at the same time..
Its all in the feel.. You'll know. Key is to minimize wheels spin as much as possible..
I'd be way to scared to do a redline launch on a bolt on car.. Just because it might **** something up pretty bad.
__________________
DO SOMETHING ABOUT IT!
Tags
14, 2006, car, clutch, coupe, dumping, g35, good, hard, infiniti, launch, mile, my350z, rpm, slipping
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
