| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Automatic Transmission rpm stuttering when slowing down
when the car is slowing down from 40mph, it feels like there is a delay in the transmission. Also, I notice the RPM jerk a little bit when it recline, it's not a smooth and response transaction.
My car has 65k miles, which i believe the warranty expired already. I went to a Nissan tuner shop this morning for oil change this morning and the mechanic said it should not be a serious issue. Any ideas? |
RPM jerk when recline? what do you mean by this? Very vague with the whole thing. Hard to even guess what you mean by "delay in the transmission" and "not smooth".
That could be anything. can you be more descriptive...and what year/model is your car.
__________________
Stillen Airbox | JWT Popcharger | Z-Tube | UR Light Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD Copper 1/2" Spacer | TB Spacer | Kinetix HFC | MD XYZ + VQ Resonated | Stillen Engine Damper | SPC Rear Camber | Stillen Sways | CircuitSport Tie Brace | 350Z Suspension |
video tape it!
__________________
IP 05 G35 Coupe 5AT: Black roof | OEM Skyline 350GT Emblem | Z-Tube | K&N filter | JDM clearcorner | 350z s-tech | Hotchkis Sways | PIAA Forza Wiper Blades |
Quote:
- When the car is set to cruise control at 65mph, the rpm is steady. It stays at 2300 rpm perfectly even when the road is sloping down or up. Does that seem odd? - What I mean by "jerking" is the car seems to be push forward by the lower gear ratio when the car is slowing down. Similar to a bad downshift in a MT shift vehicle, but I don't think it's normal for AT tran. It's a very minor "jerk", but strong enough to make me step on the brake pedal harder and wish it will go away. |
May or may not help but try resetting the ECU. Over time it makes the AT do funny things. Shorter shifts from redline and such.
__________________
'05 G35 Coupe Auto |
This may sound silly but...which one is the proper way to do it? Bring in to dealership/car tuner shop(how much)? Do the pedal reset(which style)? Unplug the battery?
The pedal reset should suffice, if that doesnt solve the issue then take off the negative terminal over night. If still persits then I would have it looked at or second opinioned.
__________________
So what's the status on this problem. I'm having something similar happening to my 06' 5AT.
My 06 AT Coupe has trans. shuddering issues, but the one I'm experiencing happens between the 2nd to 3rd shift in auto mode, very slight, and in the manual mode it clunks from 2nd to 3rd under hard acceleration. Both intermittent of course.... I had it to the dealer twice. The first time they replaced the trans valve body, then they supposedly replaced the whole thing. I just got the car in June, feeling as though I got a lemon...
To the OP, I wonder if the TC is not unlocking right away when you let off the gas pedal. Just a guess.
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash |
have you changed your trans fluid yet?
__________________
| Thread Tools | |
| Display Modes | Rate This Thread |
