MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction > Drivetrain
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 10-20-2009, 12:26 AM
nfsp1's Avatar
Just so you know, G35 Tachs aren't super precise, if you can get the data from the ECM you're much better off. I'll check mine tomorow for you. Also, basic math will help:
If you're running 3000 at a given speed with a 3.3 then:
3000/3.3*3.5=3182
__________________
03.0 IP Sedan on Z springs. Check out my website: http://www.NFSPMotorsports.com
Old 10-20-2009, 12:48 AM
Tollboothwilley's Avatar
2003 Infiniti G35
I am doing this for multiple reasons. I think that some people don't realize what differential they have. I want to know the average rpm at 80. Trying to see if all 6MT got 3.5 and all X got 3.5. Most 5AT are 3.3 but it seems some are 3.5.
__________________
Stillen Airbox | JWT Popcharger | Z-Tube | UR Light Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD Copper 1/2" Spacer | TB Spacer | Kinetix HFC | MD XYZ + VQ Resonated | Stillen Engine Damper | SPC Rear Camber | Stillen Sways | CircuitSport Tie Brace | 350Z Suspension
Old 10-20-2009, 12:54 AM
nfsp1's Avatar
Gotcha. You should also ask tire size as well.
I know mine is the 3.3 open diff, but I may be getting a 3.5 vlsd from a z.
__________________
Old 10-20-2009, 01:02 AM
2003 Infiniti G35
I realize tire size can change things, but it seems that most people are using something very close to stock size.
__________________
Old 10-20-2009, 10:48 AM
Quote:
Originally Posted by Tollboothwilley View Post
Numbers updated.
OKstateG35 - find out your numbers and post them up please.
Will do. I don't do much highway driving so it might be this weekend before I get a more accurate number.
__________________
2005 Brilliant Silver G35X
Old 10-20-2009, 11:11 AM
AARONHL's Avatar
SIX SPEED SEDAN CLUB
2004 Infiniti G35
When I drive home this from school this afternoon I'll observe the EXACT RPM @ 80mph and report back here.
__________________
Old 10-20-2009, 02:23 PM
2003 Infiniti G35
great, thanks.
__________________
Old 10-20-2009, 03:33 PM
thescreensavers's Avatar
2005 Infiniti G35
Send a message via AIM to thescreensavers Send a message via MSN to thescreensavers
I got 3050 rpm @80mph, not exactly sure which FD I have other then its has a VLSD.
stock tires 235/45R18
__________________
SFL G Club
05 OB SedanS |Z-tube|Clear Corners|
Old 10-20-2009, 10:24 PM
AARONHL's Avatar
2004 Infiniti G35
Exactly 2,900RPM @ 80MPH.
Stock tire size of 215/55-17, VLSD, with the 6MT "Sport Package".
__________________
Old 10-21-2009, 12:27 AM
2003 Infiniti G35
Hopefully I'm grouping these into the right FD since some people don't know.
I'm assuming 6MT came with 3.5 and 5AT are 3.3. I think 2005+ X are 3.5 as well.
__________________
Old 10-21-2009, 12:36 AM
AARONHL's Avatar
2004 Infiniti G35
Would it be plausible that the FD changed between years? I only say this because my 2004 is at 2900, while CandlestickPark's 2005 is at 3200, even though you grouped ours together.
__________________
Old 10-21-2009, 12:41 AM
AARONHL's Avatar
2004 Infiniti G35
I am also wondering how you know RPM differences (of even a couple hundred) can determine the FD. What would be the benefits of a lower FD, higher?
__________________
Old 10-21-2009, 12:43 AM
CandlestickPark's Avatar
Resident Nikonian
2005 Infiniti G35
Quote:
^Could tire size explain the difference. I am running 245/35 255/35. Mine does seem a little high, almost the same as Mike's 3.7 gears at 3250. I'm sure mine is at 3200 though (at least based on visually seeing the tach sit right on the 3200 line).
__________________
05 Lakeshore Slate Sedan 5AT
Team RareJDM
SxExCx - Stage4 Performance - rookie - RRYDE
Old 10-21-2009, 12:52 AM
AARONHL's Avatar
2004 Infiniti G35
More RPMs needed to hit the 80MPH mark, but I don't think ~400RPM would = ~2MPH. If you get what I'm saying?
__________________
  #30
Old 10-21-2009, 12:53 AM
2003 Infiniti G35
Candlestick is 5AT, you are 6MT. That will make a difference, as well as tire size. If you have larger than stock tires, you will reduce your rpm, and vice versa.
6MT in 6th gear with 3.3 should be around 2850
5AT in 5th gear with 3.3 should be around 2900
6MT in 6th gear with 3.5 should be around 3050 ish
5AT in 5th gear with 3.5 should be around 3150 ish
6th gear in manual is taller than the 5th gear of the auto.
__________________
Tags
2003, 2005, 80, change, g35, highway, mph, rpm, rpms, tubing
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
