Rear Tire Spinning whe exiting coners
To add to the list, also can be blown shocks and bad bushings.
Wouldn't this keep it from spinning? The spider gear of a non-LSD is made to keep from losing traction by spinning the wheels at different rates due to one being a slave.
In a straight line, yes, but as I understand it, in a turn the inside wheel spins slower so that the tire with less weight on it (less traction-inside) doesn't spin from excessive inertia.
Open diff sends power to faster spinning wheel. So under normal cornering, this is correct. Allows the inside wheel to spin slower and not slip. But once you break a tire loose, usually inside because of weight shift, then that tire will spin faster since its slipping, then it will get all the power, so then all the power goes to slipping wheel
Came in here for advice to calm the rear tires during cornering.
I got a bunch of abuse by people that know nothing about me and little about my car.
It really isn't safe right now the way it is to hammer the throttle in a corner.
I haven't had this car very long and I do not know much about it. I do like it and I want to get it hooked up...I need a girl too but that's another kind of site.
I have a bit of experience with cars and know what it should be like, Obviously, I do not have a LSD. THAT is why I came here to see what I can do to get on with this.
It is not broken as the car runs great. It just doesn't hook up traction and go correctly.
Intending to go autocross with it soon and it isn't going to work out the way it is now.
Can we get some experienced advice please?
Thanks
Thanks
