Short Throw.
knightro g35 (05-31-2014)
Urbanengineer (05-30-2014)
Nissan already put one in your car for free and you should learn to use it. Maybe look into a weighted shift **** that can be adjusted to the right height. You need a combination of leverage/height along with weight to be able to throw the shifter into each gear. You can try a TWM short shifter but you will greatly benefit from a weighted shift ****. Check out the TWM M1 abrams since that is the lowest height and still weighs almost 1 lb.
http://www.twmperformance.com/shorts...rtshifters.htm
http://www.twmshiftknobs.com/shiftkn...hiftknobs.html
For all you noobs out there...READ THE FARKING OWNERS MANUAL....geez
http://www.nicoclub.com/FSM/G35/
MANUAL TRANSMISSION Shifting
To change gears, or when upshifting or downshifting,
fully depress the clutch pedal, shift into
the appropriate gear then slowly and smoothly
release the clutch.
This vehicle is equipped with a short throw
shifter manual transmission. To ensure smooth
gear changes, fully depress the clutch pedal
before operating the shift lever. If the clutch
pedal is not fully depressed before the transmission
is shifted, a gear noise may be heard.
Transmission damage could occur
release the clutch.
I've had my B&M since 05 and it's been perfect. No rattles and smooth throw. And I've definitely put a good amount of effort into throwing the shifter fast more than once. If I've learned anything from modding my g and subi, pay for the best the first time around. OP I'd buy a B&M.
Rouge Engineering Short Throw
Whats the word my G35 bretheren?
I just got off the phone with a Mark from Rouge Engineering and he's cutting a deal to have 40 Rouge Short Throws made for the G35 coupe or Sedan. If any one is interested please let me know so I can put a list together to and some well worhty shifters made for our cars. Let me know if anyone is interested looking forward to your replies.DOMO
Freeman186
09-06-2023 10:07 AM
Learned Hand
10-01-2015 09:02 AM
