p1815 code and u1000 code
Old 08-08-2014, 11:23 AM
jmut1203's Avatar
Good Morning,
I am new to this forum and I hope you guys can help me.
2008 G35x
Recently my car has been Idling very high and not driving smoothly.
My friend has a scanner and the following transimission codes popped up
U1000 and P1815
I read up on the codes and i am still confused.
P1815 INFINITI - Manual Mode Switch WHERE IS THE MANUAL MODE SWITCH ?
Possible causes
-Harness or connectors(These switches circuit is open or shorted.) WHERE IS THE HARNESS
-Mode select switch (Built into A/T control device)
-Position select switch (Built into A/T control device)
• DTC U1000 (CAN COMM CIRCUIT)
OR
• DTC U1010 (CAN COMM) [2006 Models only]
stored in the engine control unit, and there are no drivability incidents.
PLEASE HELP !!!
Old 08-03-2016, 02:59 PM
mdp's Avatar
mdp
mdp is offline
Unhappy p1815 code and u1000 code
I'm way late to this party of 1, but I literally have the exact same problem. 2008 g35x automatic w/ the same 2 codes and idling/acceleration issues.
Any chance you ever figured this one out?
Old 01-10-2018, 03:04 PM
IllaNoizeTV's Avatar
Did you ever fix this problem? What was the solution?
RemmyZero
V36 DIY
04-23-2018 11:13 AM
KallDay86
01-08-2016 12:42 AM
joel extreme
SOCAL Meetings & Events
09-29-2015 04:44 AM
Detailed Image
09-28-2015 07:04 AM
vamarris
09-26-2015 12:56 PM
Quick Reply: p1815 code and u1000 code
