MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Technical (Do It Yourself) > Engine, Drivetrain & Forced-Induction (DIY)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #31
Old 11-06-2009, 05:55 PM
Send a message via AIM to umair
what is this about oiling and reoiling the filter???
i bought a K&N drop in and there was no oil supplied...?
  #32
Old 11-06-2009, 06:03 PM
Jeff92se's Avatar
Comes oiled
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash
  #33
Old 11-06-2009, 06:04 PM
ahhh thank you!
i was worried as ive had the filter in for a month now... so what should i use and how should i go about "reoiling" it when its time to clean?
  #34
Old 11-06-2009, 06:06 PM
Jeff92se's Avatar
Either use these instuctions or buy a K&N cleaning/oiling kit at the parts store
__________________
  #35
Old 11-06-2009, 06:07 PM
ah okay... thank you!
  #36
Old 11-07-2009, 03:53 AM
jibberjabbers's Avatar
http://www.knfilters.com/cleaning.htm
CAUTION: THE USE OF ANY OTHER CLEANING SOLUTION OR METHOD COULD DAMAGE THE FILTER!
  #37
Old 11-07-2009, 04:38 PM
of course they want you to use their stuff
the notice is there so people wont just use anything to clean the filter. I think they are trying to say dont use windex,wood polish,etc
I think I might use some simple green to get the dirt out and then clean the filter with the K&N cleaner
__________________
PM me if you need any audio help or installation of a DD or single din, im glad to help
  #38
Old 11-07-2009, 10:26 PM
JOKER's Avatar
Why so Serious?
2005 Infiniti G35 Coupe
Send a message via ICQ to JOKER Send a message via MSN to JOKER
I have tried that method and did not like it
Did not quite work for me
I use hot water and oxy clean. Works like a magic.
As a matter of fact I just cleaned it today so I'll post some pictures once it dries out.
__________________
RESISTANT
  #39
Old 11-08-2009, 01:46 AM
JOKER's Avatar
Why so Serious?
whiter part is where I have not sprayed oil yet.
That's how clean it is after washing it in hot water and oxy clean.
1. I spray the filter with cleaner (it comes in the kit, might as well use it). Let it sit for a little
2. Rinse it off with water to remove loose dirt and stuff.
3. heat up some water and pure it in the bucket with 2 scoups of oxy clean in there.
4. Submerge the filter in there and let it sit for 20 min or so.
Once all the oil is washed out of the filter it floats on top of the water so I just take few napkins and collect it so it does not get on the filter when I'll be pulling it out of the water. Water is nice and cooled off by now.
Then rinse the filter once again and dry it.
__________________
RESISTANT
Tags
air, alternative, clean, cleaning, dirty, diy, filter, filters, green, homemade, intake, kn, methods, oil, simple, solution
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
