MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Technical (Do It Yourself) > Engine, Drivetrain & Forced-Induction (DIY)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 09-13-2007, 11:53 AM
Just completed the job and it took about 2 hours and I am no mechanic by any means. Although I did mess up connecting the two rear coils on the driver side and that caused the engine to have problems on the initial fire up. I see the importance of making sure all of the wires are marked properly before taking them off or doing one at a time. Also the passenger side is a mother bear compared to the driver side. I also dropped a fastener that holds on the wire harness and the dealership did not stock those bolts; I ended up at a hardware store and found the same bolt for less than a dollar.
Thanks to everyone who put this DIY together, it really helped.
__________________
G35 2003.5 6MT Sedan
Old 09-13-2007, 12:51 PM
Hi-Tech_G's Avatar
Dream Big Achieve Greater
2004 Infiniti G35
Location: Pothole central and still ridin slammed...Beantown
LMAO....+1000
Quote:
Originally Posted by gizsf
I highly reccomend some work gloves, last time I did mine, I somehow ended up with a few good cuts and missing some skin om my knuckle.
Nice write up bro. I noticed your plugs really needed some changing. Have you noticed any difference in the vehicles performance?
__________________
VOID WARRANTYMy car sits like this /___\ and sneezes really loud...to my frenemies you know who you are....
Old 11-16-2007, 01:50 PM
pdjafari's Avatar
Supreme Allied Commander
Send a message via AIM to pdjafari
I want some donuts OINK OINK !!! lMAO
Old 12-15-2007, 07:17 PM
Boston's Avatar
FGC SFL General Member
Not sure of the firing order but the plug closest to the fire wall on the drivers side came out of the cylinder head with oil on it. The tip of the coil pack also had oil on it. Prior to the plug change I didn't notice a loss of compression. I'm not too concerned right now but if I start to foul the coil pack it's gonna be a bitch of a job. I've seen small quantities of oil in other cars but wasn't sure if it was common to the G35. Has anyone else observed small quantities of oil on any of the plugs during a plug change? Btw, the other 5 plugs were clean and had normal wear.
__________________
SFLG35
Some people are like slinkies; not really good for anything but make you smile when you push them down the stairs!
Old 12-16-2007, 12:57 PM
Boston's Avatar
^ Ok, just a follow up on the oiled plug. Ran the car hard this morning and no issues. Pulled the plug about an hour after the run and it's clean. There is still a small amount of oil in the socket and on the tip of the coil pack but nothing on the bottom of the plug.
__________________
SFLG35
Old 12-16-2007, 06:22 PM
Should we index the plugs when changing them? What size washers would you all recommend?
__________________
Florida G Club
Old 12-16-2007, 11:11 PM
hey was up guys..... i just did my spark plug change it took me like an hour in ahalf... the instruction that u gave us was so easy and straight to the point... very well done... not to bad for not being a mechanic...lol
just one questiont.....when you do the spark plug change is it normal for the service engine light togo on..? one mechanic told me that it does that and that it just needs to reset itself.....
could anyone help me and tell me if that is true?, and if not then what should i do ? thanks foryour help guys
Old 01-08-2008, 02:15 PM
DrrSeuss's Avatar
Send a message via AIM to DrrSeuss
when should the plugs be changed on our cars?
__________________
Brilliant Silver G35c 6MT
Old 01-08-2008, 08:21 PM
Built TT Motor 700whp
Quote:
I'd like to know this too.
In addition, what do you guys know about the Iridiums vs. the OEM plugs?
__________________
'03 6MT Coupe || Building a Sleeper...
Old 01-10-2008, 10:40 PM
DrrSeuss's Avatar
The OEM plugs are platinum vs. iridiums. The ones on the newer G's are iridium and the nismo ones are also iridiums. A side by side has not been done yet but I'm sure iridiums would be beneficial to us. I'm assuming that since our plugs are platinum, there should be changed every 100k miles.
I'll be changing mines out for iridiums @ 60k miles.
__________________
Old 07-07-2008, 02:52 PM
Send a message via AIM to bythabay
Spark plug replacement (part 1) (part 2) (part 3)
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html
Old 08-03-2008, 01:28 AM
PLEASE READ: mark the front of the plugs, the side with the gap, with a sharpie.
when you are tightening them, try to get the front side to face the intake side of your cylinder head.
__________________
Sedan - Totalled 4/27/09 - now an 04 coupe
Old 08-03-2008, 01:32 AM
Yeah, I am familiar with this strategy, however, in such low horsepower applications it's irrelevant, at least from what I've read. Still, it wouldn't hurt if someone went through the extra effort to mark and align.. I'd be concerned with over tightening/under tightening the plugs though; be careful.
__________________
Old 08-03-2008, 01:50 AM
hey awesome, are you the guy who made those vids on infinithelp? they are awesome, but the one for MD plenum spacer isn't working and i'm about to install one.
is there another place i can view that same video?
__________________
  #30
Old 08-03-2008, 02:00 AM
You shouldn't have any problems watching it..hmm... Try refreshing the page and let me know if it continues not to function, I'll take care of it.
__________________
Tags
2003, coupe, diy, driver, g35, g35driver, gap, grabber, howto, plastic, plug, plugs, prong, replacement, schedule, socket, spark
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
