| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
#31
NVM, i got it to work, had to uninstall flash, was being ghey.
weird cuz didn't work on ps3.... great vids man, appreciate it
__________________
Sedan - Totalled 4/27/09 - now an 04 coupe
#32
Quote:
#33
whao so I dont have to remove the intake plenum at all? Oh hell yea, I will be doing this right away then!
__________________
GARNET FIRE 03 G sedan w/ nav Homepage http://www.cardomain.com/ride/2567979 My cars build http://g35driver.com/forums/g35-sedan-v35-2003-06/178452-going-paint-shop.html |
#34
You guys can read more in detail about the spark plug tube issue here:
http://g35driver.com/forums/g35-coup...ur-60k-up.html
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html |
#35
Quote:
__________________
#36
great DIY going to use it soon
#37
has anyone tried the E3 spark plugs? I was watching Horse Power on Spike a while back and they showed that they added power and improved gas mileage... any thoughts for the G?
__________________
'03 6 speed sedan |
#38
Man am I pissed! I just installed my plugs but the front is facing away from the intake. Should I even bother or should I go ahead and fix it right away?
__________________
GARNET FIRE 03 G sedan w/ nav Homepage http://www.cardomain.com/ride/2567979 My cars build http://g35driver.com/forums/showthread.php?t=178452 |
#39
any help would be nice guys....................................
__________________
#40
ok I just took it for cruise, I do notice more power with the new plugs but is it worth taking out again just to make sure the front of the plugs are pointing towards the intake?
__________________
#41
ok I guess it doesn't matter because my ride seems like it turned into a beast, now Im stuck on making MORE POWER! Muahahahaha!
__________________
#42
hey guys some help advice plz...... i followed this DIY and i just changed out my driver side plugs since its getting dark today ...i didnt change the passenger side yet. theres the problem.. on the Driver side Rear plug..when i took the coil tube out ,there were oil on it..i wiped it off then took the spark plug out..WOW there were lots and ALOT OF OILS ON THE SPLUG!....both Driver Mid and Front were fine normal wear....does any body know what could be wrong? im guessing the valve cover gasket need to be replace ??? and i noticed i am burning oil cause every time when i check my dipstick it gets lower and lower...i had to put 1/2 - 1 quart every 1,500 miles. if anybody got an idea please advice me up!!! thanks! i am going to change out the passenger side tomorrow morning!!
PS: My car is 03 coupe AT with about 56,000 miles on it
__________________
http://officialtsz.com/ |
#43
was there oil on the spark plug tips or just on the white ceramic part that coil goes into?
__________________
![]() A nickel bag gets sold in the park I want in |
#44
Quote:
http://g35driver.com/forums/g35-coup...rranty-up.html Looks like you'll need new valve covers, as just the spark plug tube seals separately aren't available. Let me know if you need any help replacing them.
__________________
#45
its all over spark tips and screw threads~~not on the white ceramic part yet.
some on the coil pack tubes had to be wiped down....
__________________
| Tags |
| 2003, coupe, diy, driver, g35, g35driver, gap, grabber, howto, plastic, plug, plugs, prong, replacement, schedule, socket, spark |
| Thread Tools | |
| Display Modes | Rate This Thread |
