DIY: WRP Under-Drive Lightweight Crank Pulley installed
on
If you've ever built engines you would understand. The rotating assembly (on a proper build) is balanced. The OEM assembly is balanced with the stock harmonic balancer and therefore I cannot justify possibly wrecking my engine by throwing off the balance for ~10whp at the most. Cooler weather can do that for you without harm.
I've never used one, but I know plenty of people that do. I feel the same as you - I don't want to take that risk for a mere 10 HP.
Red Card Crew
It's not the dia change. It's the fact that people use light flywheels with no apparent concerns. Also the flywheel dia is alot larger than a pulley so any slight harmonic changes are bigger in a flywheel. On top of it all, light flywheels typically represent 8-15 lbs of mas reduction vs just 3-5 with a pulley. If there's any upset in balancing, I'd think it would be on the flywheel side and not the pulley side.
I did the install today and there is a significant difference between the stock/UD pulley; this thread helped out a lot; 12mm sockets are needed for the long tensioner bolts, 14mm sockets for the pullies and the shorter belts are a must; when I bought the pulley I was told the stock belts would work and they don't.
I broke a 3/8 ratchet and a 1/2 adapter trying to get the crank bolt out...I used a 1/2 breaker bar, cheater bar and the bumping over of the engine to get the crank bolt loose.
I had to bump the engine 2-3 times.
I will see how it feels after driving it the upcoming week.
