DIY: Plenum Spacer Install Guide (MotorDyne 5/16" Basic and others)
Old 05-08-2010, 09:04 PM
mckma's Avatar
Originally Posted by mckma
just reset the throttle body , as recommended by motodyne ,much mure responsive and punchy, but for now i think if i where to do it again i would just go with a ztube and a jwt pop c-
scatch that i like the plenum, the increase in power at the shift mid to top end, just spanked a fx45 from 60 to 120 3 times he finally gave up,,
  #32
Old 05-23-2010, 05:10 PM
tgeml's Avatar
Great writeup, I used your guide word for word when i installed my 5/16ths MD plenum with no problems, i did loctite all my threads though for peace of mind. Keep up the great work, I praying you decide to put some coilovers on your car with a guide so we all get another great guide!
  #33
Old 05-24-2010, 09:31 AM
mckma's Avatar
the plenum i guess, help me pull away at the shift " with the plenum i notice a jump in power at the shift" the guy must have thought that i had nitrous or something
  #34
Old 05-26-2010, 11:16 PM
CHI-TOWNG35's Avatar
Very good site i have used these write ups for iPod adapter, and plenum install.
  #35
Old 05-24-2011, 10:17 PM
curin323's Avatar
just did it today. so helpful..took me 25 mins
  #36
Old 07-17-2011, 11:13 AM
Nail's Avatar
Installed mine the other day using this guide, great work!
BUT one complaint. I'm not sure if this was my fault or what, but while torquing the 18 bolts, my wrench wasn't working properly, it wasn't clicking how torque wrench's should. So I decided to skip right to 90ft/lbs, as the instructions from Motordyne suggest, and I snapped a bolt in half with one crank of the wrench.
Also, how do I get rid of the "service engine soon" light? Reset the throttle body?
  #37
Old 12-06-2011, 02:35 PM
757_G35's Avatar
Awesome... I'm actually picking one up tomorrow... Thanks...
  #38
Old 12-09-2011, 04:04 AM
L50K's Avatar
lol i installed mine and then my plenum cracked. good ol jb kwik is making a good temp fix
  #39
Old 12-09-2011, 04:49 PM
757_G35's Avatar
^^ What happened??? Did you over torque it???
Well, I installed mine this morning... The install went great and the car is running like a champ... Did the front brakes as well... Busy morning... Thanks for the DIY...
  #40
Old 01-05-2012, 07:52 PM
DaGdriver's Avatar
Thanks bro!
  #41
Old 01-14-2012, 09:46 PM
bluranver6's Avatar
i did mine the other day very good DIY only thing was the check engine light was on before and i reset it and it came back on i had it looked up one time but dont remember what the code was its annoying and i dont want to take it to a stealership to figure out what it is
  #42
Old 03-09-2012, 08:33 AM
ohsixmtee's Avatar
Very nice work, perfect write up! Does the spacer screw with idle or overall behavior in any negative manor? 200 bucks for a 11 to 13 proven gain sounds pretty nice.
  #43
Old 03-20-2012, 12:44 PM
slim17265's Avatar
I would like to have just one person say it increased performance from 2000 rpm and up...why...because the factory has all of the tools and they are much smarter than the back yard mechinics....when they make something it takes in consideration the driver that drives in steady city traffic and needs TORQUE....then we have the driver that lives in the suburbs with many great roads to drive on with no stops etc. here is a driver that appreciates power above 3000rpm.... so when CHANGING something that the factory has designed for ALL drivers take that into consideration....if you change the airflo you will most likely pick up 3 hp above 3000rpm and lose 4 lbs of torque below. so what do you want.?
  #44
Old 03-22-2012, 05:49 PM
AVB22's Avatar
Very easy install and MD sends instructions that are on point if you buy from them
  #45
Old 06-10-2013, 01:50 PM
Big Booty Trudy's Avatar
So a shop would charge me $150-$300 to install my spacer. Is this something anyone could do with basic tools? I am not a mechanic by any means but I have installed springs, coilovers, camber kit.
Quick Reply: DIY: Plenum Spacer Install Guide (MotorDyne 5/16" Basic and others)
