DIY:*FIX* Coolant Air Bubble [ Heater not working / Temperature jumps / Loud BOOM ]
#46
AARONHL - Seems like an unusual problem. I recommend draining the fluid and starting over. DO the bleeder a couple times. If the problem still persists unless you have deer fur in a radiator hose my last guess would be the heater core. IF so I can only say good luck . Hopefully someone else can chime in with a better explanation to solve your problem . I'm really not positive!
I might send you a pm today about the sedan decals
#58
AARONHL, did you ever fix the problem after the new radiator? I'm having the same problem now. It doesn't really bother me that much since the car isn't overheating, but it's definitely annoying.
This happened after I drained/refilled the coolant. Doesn't seem like it's circulating to some areas. My fans kick on just fine, and I can spit coolant out the cap and bleeder valve just fine but can't get anymore bubbles to come out. I did get a good amount of them out, seems like there's one giant one stopping me. Lower radiator hose remains cold even after a 20 min drive. FWIW, I poured in the new coolant slow as hell, like 4-5 minutes to put a gallon in there.
