DIY: Spark Plug Tube Seal Replacement
Old 11-22-2013, 01:03 PM
G35TSS's Avatar
1. Disconnect battery Ground (-).
2. Remove the engine cover.
3. Disconnect the MAF sensor and vacuum hose connected to the intake tube.
4. Remove the air intake from the throttle body to the air filter.
5. Remove the upper plenum in reverse order from 18 to 1.
6. Remove the vacuum hose near bolt #13.
7. Lift up and tilt back the upper plenum and hold it up with bungee cords, twine, etc.
8. Remove the vacuum hose from the front of the lower plenum and rear of the upper plenum near the throttle body.
9. Remove the lower plenum in reverse order from 8 to 1.
10. After removing the lower plenum immediately plug the intake holes with paper towels and cover with shop rags to keep debris out of the cylinders.
11. Remove the wire harness bolts to give yourself space to remove the valve covers.
12. Label and remove the coil packs. They must go back exactly where they came from.
13. Remove the vacuum hose in the top front that connects both valve covers together.
14. Start with either the driver side or passenger side valve cover by removing perimeter bolts.
15. After removing all 10 bolts lift up on the valve cover to clear the cam shafts, push back and work out carefully.
16. Once all covers removed, carefully remove gasket material from heads and intake manifold.
17. There's 3 seals per valve cover as seen above, secured by the baffle plate. WARNING!!! DO NOT REMOVE THE BAFFLE PLATES.
18. Secure the valve cover to your drill press and and cover area arounfd the hole your drilling with shop rags to prevent debris from getting behind the baffle plate.
19. Using a 1 7/8in hole saw, drill out a few millimeters deep through the baffle plate.
20. Once the seal is exposed, you may have to drill just slightly larger than 1 7/8in, pop out the seals by flipping the cover over and tapping out.
21. After seals have been removed thoroughly clean the area where the new seals will go, rtv will not stick to oil/debris.
22. Run a small bead of black rtv around the outer groove of the rings and pop in the new seals.
23. After new seals have been inserted run another bead of black rtv around the top of the seal and allow plenty of time to cure.
24. Once cured; Re-assemble valve covers with new gaskets, lower plenum with a new gasket, and upper plenum with a new gasket, air intake and battery Ground (-).
***Be sure all vacuum/coolant lines are reconnected.
***Be very careful when re-attaching the upper plenum not to pinch the oil cap rubber between the upper and lower plenums.
***If you encounter a Check Engine Light, disconnect battery Ground (-) an check all sensors/hoses are properly connected. To reset the CEL, while Ground is disconnected tap the brakes a few times, reconnect Ground and retry.
Send a pm if you need some spark plug tube seals.
Good Luck,
Joe
The following 2 users liked this post by G35TSS:
Gilley (11-25-2013), Ouija (03-26-2014)
Old 11-22-2013, 08:15 PM
redonblack35's Avatar
Here's a cool alternative for the Do It Yourselfers! Thanks!
Old 11-22-2013, 11:03 PM
saywat?'s Avatar
op u went with the r&d/l-fab seals?
Old 11-25-2013, 07:06 PM
Gilley's Avatar
Thanks for the pics. Which seals did you use?
Old 02-20-2014, 09:54 PM
Turbo TA's Avatar
Where did you get the seals? Thanks.
Old 02-21-2014, 10:01 AM
G35TSS's Avatar
Hi Turbo, I have the seals, plenty of them. Send me a pm and I can help you out.
Have Friday,
-Joe
Old 02-21-2014, 01:11 PM
saywat?'s Avatar
wat do u mean u have the seals?
Old 02-21-2014, 02:43 PM
G35TSS's Avatar
Please send me a private message for further inquiries.
Thank you,
Joe
alecz86 (04-03-2014)
Old 05-14-2014, 10:48 PM
Awakened2001's Avatar
Spark plug tubes
I am curious does anyone know how to remove the spark plug tubes themselves? i have some carbon built up from a misfire in #3 that i am having trouble removing. I was told to use an impact socket inside of the tube and a vicegrip on the outside to grip the tube and work it off but with how firm it seems im afraid it will damage the tube. Im trying to solve the oil leaking into my spark plug tubes problem that i've heard quite a bit about as well got new gasket for the valve covers but my VC's are still in perfect condition aside from the tube seals that im assuming are the culprits of my leak. I noticed a ring-shaped gap in the middle of the tube seals and im curious couldn't you just clean them up and run a thick bead of RTV in that groove to seal the tubes up without the drilling and new rubber rings? I apologize if thats a dumb question im just having trouble understanding how those seals would allow oil over and into the plug tubes. I really dont want to drop hundreds of dollars on new vc's over a rediculous design flaw and what should be a 10$ seal.
Old 08-15-2014, 05:29 AM
Srdatsun's Avatar
My driver side valve cover seals are leaking as well.
Didn't know this could be done.
Send a price on the seals if you still have any.
Thanks
Old 07-23-2019, 11:05 PM
miamichillin99's Avatar
Anyone have the original pics of this how to?
Old 10-09-2019, 05:12 PM
6MTsedanlife's Avatar
2004 6MT sedan
Spark plug seals
Have Friday,
-Joe
Do you still have any seals?
Old 12-31-2019, 07:14 PM
ramwatt's Avatar
I could use some of these seals for factory valve cover. rickwatts9@gmail.com
Terry_G35
05-09-2020 01:39 AM
wuppiedog
08-07-2015 11:16 AM
ghost_g35
08-07-2015 10:31 AM
Terry_G35
08-04-2015 02:38 PM
G35OUTLAW6MT
07-13-2015 02:26 PM
Quick Reply: DIY: Spark Plug Tube Seal Replacement
