| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| View Poll Results: Year/Model of your G having EXCESSIVE OIL CONSUMPTION | |||
| 2003 5AT |
36 | 8.65% |
| 2003 6MT |
45 | 10.82% |
| 2004 5AT |
24 | 5.77% |
| 2004 6MT |
38 | 9.13% |
| 2005 5AT |
18 | 4.33% |
| 2005 6MT |
115 | 27.64% |
| 2006 5AT |
12 | 2.88% |
| 2006 6MT |
110 | 26.44% |
| 2007 5AT |
6 | 1.44% |
| 2007 6MT |
12 | 2.88% |
| Voters: 416. You may not vote on this poll | |||
Thread Tools | Rate Thread | Display Modes |
#61
As long as you keep your oil and filter purchase receipts, they should still honor the warranty.
If you think you have an oil burning problem, though, you have to take it to a dealer to have an Oil Consumption Test done. From what I've read, they will fill the car with the proper amount of oil and "seal" the dipstick and drain plug to prevent tampering. You will then drive for a predetermined mileage and bring the car back for them to see how much oil is left. |
#62
had this done at the dealer, they say i'm burning 3/16ths of a quart in 1000 miles and that's ok. Oh well, I guess that's a quart or 2 every oil change. Is it ok if I switch back to synthetic blend if I've gone from blend to syntehtic for about 6000 miles?
#63
I am scheduled next week for an oil consumption test. I burn about 1QT every 1000 miles. The person at the Infiniti dealer told me to come in for the "oil consumption test" so I'm wondering how common this all is. I don't drive the car hard, I mostly drive it 1-2 times a week to work and on the weekends with the kids.
I first time I noticed this issue was when my car started making the "engine gone wrong" clanking sounds. After adding oil, it seems to be working ok. I don't expect the car to last long with this issue but I've been really watching the oil. My BIG question: I have the following engine/exhaust mods on my car: MREV2, Stillen intake, carbon Z-tube, 5/16 spacer, stillen damper & intimidator exhaust. What if anything should I revert back to stock? Thanks!
__________________
SOLD 2006 G36 Couple - 6MT, Premium, Aero & XM. For Sale - Volk GT-S, Intimidator Exhaust & Stoptech BBK Fronts & Matching Rear Rotors. |
#64
Some Dealers are okay with mods, some not.
If it were me, I'd take the MREV2 off. It is actually for off-road use, meaning it's really not legal for the streets and you might get hassled about that. But again, some Dealers don't care about that mod. Your other mods I'd say your ok with those, imo.
__________________
06 DG 6mt|Aero|RAS|Mods|Revup VQ replacement. |
#65
response to 2 posts above... based on the poll it looks like it's pretty common with 05 & 06 MT (which you have)... as far as what mods to revert to stock - I would go entirely back to stock just to be on the safe side... Most people will tell you they have to prove that the mod caused the problem, and with the problem so common it’s not likely to be caused by your mods - but I would rather cut through the BS with the dealer & manufacturer so if it were me I'd go bone stock till the tests are conclusive.
BTW, I have all the normal mods like you and my dealer has absolutely no problem with them... however you might be looking at a major warranty issue so better to be safe then sorry. Just my .02 Last edited by OCG35; 01-04-2007 at 12:06 PM. |
#66
Not sure if it was in this thread, but I read this problem seems to be related to the 298 Revup motor (might have that wrong). Did Infinity change the motor later in '06?
#67
Quote:
#68
anyone notice this, for the first 17k on syn blend never bruned a drop, i swithced to mobile one syn at 17k and started burning oil, until my oil change at 22k i burned about 2 quarts total. I'm thinking of switching back to blend
#69
Can you identify the MREV2 by looking at it? I couldn't easily tell the difference between stock and the MREV2 when it was installed. I've had 1 oil change at the dealership since installation and they didn't say anything about the spacer but did say the intake & exhaust was nice.
I am not sure I want to remove the parts because I will have to pay for removal & re-install. Also, if they try to deny warranty to me I would get a lawyer and pursue this. I don't want to set myself up for a hassle but I would stick with it for a $38K MSRP vehicle with only 6000 miles on it. Remove & replace MREV + Spacer could cost me a few hundred bucks easy. Not sure what to do here...better safe than sorry I agree.
__________________
#70
The bottom end of the VQ suffers from high crank case pressure -- which pushes into the head and cam area -- also has high vacuum which sucks the oil through the vent tube back through the intake to be burned... this is magnified at high RPM which the REVUP is good at. I am tired of the consumption and am starting the tear down of my motor on Monday for a complete buildup. Get some quality products in there so I can stop worrying.
__________________
2005 DG 4D 6M-Procharged-Kinetix SSV-Kinetix Cats-Stillen GenII Cat Back-JWT Clutch & Flywheel-Tein Basics-19X8.5 HP Lighting SS-Stoptech BBK-Wisco Pistons-Eagle Rods-Way to much money spent! |
#71
I'm out too, it sux.
http://www.g35driver.com/forums/show....php?p=1646982 |
#72
The results really are biased. If you can include users without a problem to compare to the ones with a problem you would have much better results.
#73
2 engines down so far.. They are doing my 2nd oil consumption check..
__________________
07- Aprilia RSVR, 03 - Sport trac, 04 Victory Vegas, 67 MGB-GT, 00 Monterey 180 Edge, 06 6MT Kinetix Hi-Flow Cats, Kinetix Plenum, No-Frills CAI Injen SES |
#74
So this isn't a problem with the 2007 6MT??
__________________
07 6MT Coupe|Aero|Sirius|30% Tint|Clear Corners|Stillen Intake|Ztube|5/16 Spacer|Polarg LEDs|Side Mirror Tint - Blue Ice|Tail Overlays|V1|Sunpac| "How come the SLIP light always comes on when i've been drinking? Does it have some kind of alcohol sensor or something?" |
#75
Quote:
__________________
2006 AB 6MT Coupe : Vortech SC : FI Intimidator : FI HFC's : HKS FCon iS : Tein Flex : EDFC : Work VS-XX : Toyo : Eibach : Hotchkis : Kics R40 : Walbro : Deatschwerks : Defi : Innovate : Aquamist : Exedy : Motordyne : Top Secret : GTM : STATUS : Fast Intentions : SurfaceMODz : R Rides : |
| Tags |
| 10102ac7m1, 2003, 6mt, consumption, end, g35driver, interval, malibu, oil, poll, post, usage, vq35de, vq35hr, wards |
| Thread Tools | |
| Display Modes | Rate This Thread |
