How much is it to replace a blown motor?
8k from the dealer. If you don't want to spend that much money find a motor from a totaled Z or G (shouldn't cost you more than 3k) and a proffessional shop that will warranty an install. My friend blew his motor in his 350z (accidentally hit the NOS while in netrual). He brought a motor from a junkyard with about 28k on for 2800.00. He then went by a dealership and cut a side deal with two of the mechanics there and got his motor installed with a few extra goodies for 1500.00
on
Luckily I have never blown a motor, I am just curious if I do.
But thing is that people here are saying anywhere between $4k for a used motor and install all the way up to over $15k for a new one with dealer install.
That is a HUGE difference.
Anyone else have examples?
And where would one find a spare engine? Any online resources? Special junkyards? Etc...?
Here.
http://sgpracing-store.stores.yahoo.net/sgpravqmo.html
If your shortblock is busted then 6K you can have a short block that is good for 650 WHP.
Upgraded Shortblock: $3990 + $2200 core - Good up to 650 Rwhp
**This core charge is charged when shipping an upgraded block to you before you return your block. The core charge will be refunded once a rebuildable core is returned to us. Must include a usable Block, Crank & Main Girdle.**
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/*ceramic coating
*Pauter Rods / Carrillo Rods
ARP Rod Bolts
*CP Pistons .020 over(8.5:1 or 11.5:1) ** Ceramic Coated **
Or for the ladies:
Basic short block: $2950 + $2200 core - Good up to 550 Rwhp
Block redecked
Crank balanced
Eagle rods
ARP Rod Studs
New Rod and Main bearings
Wiseco Pistons .020 over(8.5:1 or 11.5:1)OR CP Pistons for + 400.00
Block redecked
Crank balanced
ARP Rod Bolts
Or for the ladies:
Block redecked
Crank balanced
Eagle rods
ARP Rod Studs
