| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
I love the product i have it in my 2003 g35. I loose the lag. The rpm just climbs faster. I went into the store, they install it telling me nothing and after i went for a quick test drive they ask me if i saw a difference. And i saw a big difference and i bought it.
I've got this on my Nissan Maxima and I love it. Makes heel toe driving so much easier in this car because I have small feet. Remaps the throttle for quicker response.
There is a write up on pasmag and on the porsche cayman forums you guys could check out. Retail is 329 CDN but I can get them for 299.99 CDN for those who are interested. Not sure what the rules are on a group buy, but it would be this price for 1 or 10 people. Here's the pasmag writeup for a 350Z install ![]() I can post the cayman link when I find it again
__________________
03 Maxima | 6spd | I/H/E | 253.50 fwhp |249.75 lb/ft tq |
not completely true.
Accomplishes the same thing with a different method... from everything I've been able to determine about SB, it quickens the response of accelerator... Orisis allows for variable percentage of throttle plate opening to accelerator pedal depressing... if you want the throttle plate to open 30% more when pressing accelerator a certain distance, it’s done. I'm quite certain TS can do similar.
Accomplishes the same thing.
__________________
Link to "My Garage" for info about the car |
Quote:
The only possible acceleration improvement etc. would be if the stock throttle doesn't take the system to 100% and the SB does. There are a couple of other alternatives that I think may actually have some use as you can change the sensitivity of the throttle so you can more easily go for economy, etc., but in the end you are not going to win any more races, gain hp, over the stock setup no matter how much may feel like you will, that is unless the .05 seconds happens to come into play. When you think of it, it is not much different than if you put a wedge in front of your pedal to change the angle. One thing to consider is that the device would be in both directions. If your response takes .05 seconds less time to go to full throttle, then the way it functions means it will take .05 seconds longer to get off the throttle.
__________________
Eagles may soar but weasels don't get caught in jet engines
Well for older G35 autos, it might also help with the pesky torque management that Infinti overdid on our early versions. It always created a big lag just off idle.
plenum mods helped but I just got done putting in the F-Spec flash from TS. And the annoying low end lag is greatly if not almost 100% eliminated. This thing is what? $300? I was able to get in the TS dyno meet deal prices and got the F-spec for $425+shipping. So for an extra $125+shipping, you get a/f, ign, TB 100%, 500 rpm redline increase and adjustments for any mods. TS could be receptive to offer their dyno day pricing for a select few but I dunno
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash |
| Tags |
| 350z, 5at, aero, automatic, bad, booster, code, g35, install, module, spring, sprint, sprintbooster, stage, wot |
| Thread Tools | |
| Display Modes | Rate This Thread |
