| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
that was from a year ago...
I was able to install it with all 3, just had to create a hole in the side of the frame rail to get 2 nuts on the end of the bolts. Sedans do have the existing threaded holes, just not the early sedans. THey are the bastard child of Infiniti. Different ECU, mechanical fan, doggy door, lots of weird differences.
__________________
Stillen Airbox | JWT Popcharger | Z-Tube | UR Light Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD Copper 1/2" Spacer | TB Spacer | Kinetix HFC | MD XYZ + VQ Resonated | Stillen Engine Damper | SPC Rear Camber | Stillen Sways | CircuitSport Tie Brace | 350Z Suspension |
Quote:
__________________
2003 G35 DP Coupe 5AT |
I tired it with 1 screw...holds MUCH MUCH better with 3
__________________
| Tags |
| 2006, 350z, 350zg35, brace, crank, damper, dampers, engine, g35driver, hood, install, pulley, stillen, suck, ur, z33, z350 |
| Thread Tools | |
| Display Modes | Rate This Thread |
