MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 04-18-2009, 12:17 PM
are you guys checking everything else to make sure these are all ok? thread width and length of the filters are just 2 factors, you have to make sure the internals are all made for that specific car like if there is a valve inside and other things. i get worried about putting a different filter on a car just because its a little bigger.
__________________
2006 DG 5AT Coupe, sport, premium, aero, Stance GR+ Pro coils, SPC camber kits
Old 04-18-2009, 01:31 PM
^wtf, a valve?
__________________
Sedan - Totalled 4/27/09 - now an 04 coupe
Old 04-18-2009, 02:54 PM
There is a bypass valve in an oil filter.
When the filter media becomes clogged or so blocked oil cannot flow well, the bypass valve opens and allows the oil to circulate through unfiltered.
Some also feature anti-drainback valves which keep oil up in the engine rather than letting it flow all back into the pan once you shut your engine off
__________________
2006 G35x Sedan // Black Obsidian/Stone // Premium C + NAV // Stock + 35% Tint/OEM Ipod integration kit //
Old 04-18-2009, 04:00 PM
2006 Infiniti G35
Send a message via AIM to BH818
Quote:
Originally Posted by tt88supraman View Post
ya i'm getting royal purple oil. i didn't know royal purple made filters. i guess ill go with royal purple filters as well.
the model # 10-2876
Old 04-18-2009, 04:17 PM
yes, a valve, just like stated. some of those valve are activated at different pressures, so if you get a filter with a valve that opens with less pressure than was originally designed for the car, oil could possibly be going through unfilterd. and the other valve he mentioned is for dry starts. if the oil if kept in the engine instead of draining back into the filter, this helps lubricate the engine right away at startup
__________________
Old 04-18-2009, 04:33 PM
aBLUEg35's Avatar
2006 Infiniti G35
i'd be interested to find out if its the same seeing the g35 filter is about the same as the one on my lawn mower lol
__________________
JWT&ztube/MDspacer/BerkHFC/Borla/viper/GroundingGear/StillinDamper/Cobb/Stoptech
Old 04-18-2009, 06:44 PM
More than likely it is identical, just a longer cartidge.
I cannot confirm this. ANyone wanna buy one of each and cut them open to confirm?
__________________
Old 04-19-2009, 12:00 PM
2004 Infiniti G35
circled everything that's different
looks like it's just a longer cartridge
Old 04-19-2009, 01:29 PM
nice find, what is the beta ratio and burst pressure?
__________________
Old 04-19-2009, 03:06 PM
2004 Infiniti G35
Quote:
It takes some juice to get through the shell of a quality oil filter. The strength of this shell is very important. If the shell is too thin or poorly joined at the base rupture can occur. Rapid loss of oil and pressure will result in engine damage. Measure of the shell strength is referred to as burst pressure.
info on beta ratio: http://www.oilanalysis.com/article_d...?articleid=564
__________________
2004 DG Brembo Coupe Z-tube & POP Charger | 5/16" MD Iso Thermal | Project Mu NS
Old 04-19-2009, 06:28 PM
Guess i'm getting a 51356 next change
__________________
Old 04-19-2009, 06:45 PM
where do you guys get your wix filters at?
__________________
Old 04-19-2009, 10:17 PM
BuckeyeInMI's Avatar
OEM Mod Squad
2005 Infiniti G35
Just got one yesterday at a NAPA store. It's a NAPA GOLD 1356, cost $7.95. Got it along with a case of Amsoil 5W-30 for my switchover to synthetic.
__________________
2005 Diamond Graphite G35x |OEM Z-Tube|K&N|HR Z Y|MD 5/16ths Cu ISO|Rev-up Airbox|SBD 10 Wire|Bump Clears-Blinker Mod|Coupe 18's|RE760 Sports|
Old 04-19-2009, 10:26 PM
I use Castol 5/30 full synthetic it's more money but who cares protects engine well
  #30
Old 04-19-2009, 10:57 PM
2006 Infiniti G35
Quote:
More money is royal purple at $9 a quart
Tags
102876, 2006, 51365, change, diy, engines, filter, filters, g35, mobil, nisson, oil, purple, royal, wix
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
