| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
#46
Quote:
is the same in both filters or not??
__________________
OTSZ crew
#47
The 51656 actually has a higher burst pressure. Everything else is the same. The longer one is used for the maxima which has the same engine. And is actually cheaper by about $0.50
51356 Part Number: 51356 UPC Number: 765809513563 Principal Application: Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-09), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip. All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.402 Outer Diameter Top: 2.685 Outer Diameter Bottom: Closed Thread Size: 20X1.5 MM By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=6/19 Burst Pressure-PSI: 363 Max Flow Rate: 9-11 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.475 2.173 0.233 51365: Part Number: 51365 UPC Number: 765809513655 Principal Application: Ford (92-97), Honda (00-07), Infiniti/Nissan (95-09), Mazda (97-07), Mercury (91-96), Saab (05-06), Subaru (88-09), Cub Cadet, Yanmar, John Deere, Kawasaki, Kobelco, Outboard Marine Engines, Subaru 4EAT, R4AX-EL spin-on transmission filter All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 2.577 Outer Diameter Top: 2.685 Outer Diameter Bottom: Closed Thread Size: 20X1.5 MM By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=15/22 Burst Pressure-PSI: 300 Max Flow Rate: 9-11 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.475 2.173 0.233
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash |
#48
not sure if the "36 psi " makes a difference in "burst pressure" ..
is the difference good or bad .. ??? is it ok to go with the longer filter ?? edit: n/m
__________________
OTSZ crew
#49
Using the longer maxima VQ35 filter is just FINE!
But if you are so worried about the burst pressure. Higher = better. Quote:
__________________
#50
gracias muchacho ...just double checkin the facts .. lol
__________________
OTSZ crew
#51
I run the Mobile 1 107 filter due to my sandwhich adapter and 7 qts of Amsoil 0w-30. DIY ftw!
__________________
Relentless Autosports G35 Twin Turbo - Built 5AT - SGP Valve Body - JWT - Fast Intentions - Megan - NISMO - GReddy - Defi - Koyo - Nitto Need cams? FS: JWT S1 Cams Brand New |
#52
btw hows amsoil? u r running that 20000 mile synthetic oil? amsoil had a booth out in local fair. one of da representatives were yapping about how great they r and blah blah blah...
__________________
05 AT lakeshore slate coupe~debadged~jwt pop charger~TEIN H-tech~
#53
It does the job just fine. I've never got a UOA, but I drive my car hard all the time and I'm over 30k boosted stock block miles. I still change my oil every 3k miles, regardless of how long it says you can go.
__________________
#54
Amsoil is probably the best or one of the top 3 at least of all oils available. Canadian, you should do an UOA just for kicks.
__________________
#55
Quote:
__________________
#56
blackstone labs. just email them and they send you the sample bottles free
__________________
#57
Quote:
__________________
#58
would the M1-108 be equal to the M1-110 ??
i was trying to find specs between the 2 but no luck so far.....
__________________
OTSZ crew
#59
Champion Labs mades Mobil 1 filters. Reviews say it's a quality unit. But at $10, it's expensive. I'd run the Napa Gold or Wix filters and order them from Fleet filters for less than $5 each. Off the shelf, I'd go Purolator Pure 1 which is another highly rated filter.
__________________
| Tags |
| 102876, 2006, 51365, change, diy, engines, filter, filters, g35, mobil, nisson, oil, purple, royal, wix |
| Thread Tools | |
| Display Modes | Rate This Thread |
