MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
  #61
Old 10-25-2009, 05:50 PM
Send a message via AIM to umair
and whats the deal with oil filters???
i see people are substituting the G35 filters for the M fliters???
  #62
Old 10-25-2009, 06:15 PM
thescreensavers's Avatar
2005 Infiniti G35
Send a message via AIM to thescreensavers Send a message via MSN to thescreensavers
Quote:
Originally Posted by umair View Post
alright guys im using castrol full synthetic 5/30... should i be using mobil???
according to Oil Analysis it shows Castrol syntec 5w30 being better the M1, but make your own decision. They are both good.
__________________
SFL G Club
05 OB SedanS |Z-tube|Clear Corners|
  #63
Old 10-25-2009, 06:27 PM
Quote:
yeah so i thought too but i saw everyone using mobil so i didnt know if i had missed some significance for mobil over castrol...
thanks!
you got any advice on filters?
  #64
Old 10-27-2009, 11:34 PM
TbagzG35's Avatar
amsoil all day
  #65
Old 10-27-2009, 11:40 PM
amsoil huh... any autoparts store auto store carries it?
  #66
Old 10-28-2009, 12:04 AM
2006 Infiniti G35
Send a message via AIM to BH818
Quote:
Originally Posted by TbagzG35 View Post
amsoil all day
are there any dyno tests with this oil?
check out the Eneos oil 0w-50 dynos
its japanese racing oil
http://www.youtube.com/watch?v=2eDc3msmXDo
^ 350z DYNO'ed
http://www.youtube.com/watch?v=Z3p-WXDTwyo
^335I
http://www.youtube.com/watch?v=vmLP95N_DX0
^ EVO
http://www.youtube.com/watch?v=HrTrdw8btzQ
^ Corvette
I'm switch to these oil next time
  #67
Old 10-28-2009, 05:36 AM
2005 Infiniti G35 Coupe
^ 350z DYNO'ed
^335I
^ EVO
^ Corvette
question is how much is it? royal purples 9 bux a quart. if its over 10bux a quart i rather stick with royal purple lol
__________________
05 AT lakeshore slate coupe~debadged~jwt pop charger~TEIN H-tech~
  #68
Old 10-28-2009, 06:04 AM
2006 Infiniti G35
Quote:
I'm using royal purple now
I know a shop in Van Nuys (Sourthern California)
they sell them for
"Eneos oil with factory filter, washer and 5W-30:$54.95
Eneos oil with factory filter, washer and 5W-20 or 0W-20 (5 Qts.)$64.95
Eneos oil with factory filter, washer and 0W-50 (6 Qts):$74.95"
  #69
Old 10-28-2009, 08:42 AM
gShack.org
^ 350z DYNO'ed
Apples to oranges, they compared 20w50 with 0w50. You may also want to read on the pros/cons of using race oil for daily driving.
  #70
Old 10-28-2009, 02:08 PM
Jeff92se's Avatar
50 weight is WAAAAYYY too thick for an oem built motor. 20W is WAAAYY too thick for a winter weight.
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash
  #71
Old 10-28-2009, 06:38 PM
pfarmer's Avatar
Quote:
In our area 20W should be fine for the Winter weight part of the figure (most of the time). According to charts it should be ok down to about 0 F. 15W to about -10, 10W to about -20, 5W to about -30.
__________________
Eagles may soar but weasels don't get caught in jet engines
  #72
Old 10-28-2009, 06:47 PM
Jeff92se's Avatar
Don't know why one would want to run 3 times the rated winter viscosity if they didn't have to. (and stress the oiling system w/o need)
__________________
  #73
Old 10-28-2009, 10:13 PM
pfarmer's Avatar
It is not 3 times the viscosity. 20W is the same minimum viscosity at 212 degrees F as 20 weight oil but not at the winter temperature rating. As an example with 15W oil at 5 degrees F you have the same rating as 5W oil at -13 degrees F. At 212 degrees F #15W is rated the same as 20W and single weight 20. These are minimum values. Maximum value ratios are a little different. As a comparison single weight 30 has a viscosity rating of about 25% higher than single weight 20, not a 50% increase that may have been guessed by many. 20W oil at its temperature rating of 14 degrees F has a viscosity of about 30% higher than 5W oil at is low temperature rating.
For this reason I would not use a higher oil than 15W in most northern places in the U.S. On the other hand its pumping capability is the same at -4 degrees F as 5W is at -31 degrees F. In other words if you can crank it, it will pump.
__________________
  #74
Old 10-28-2009, 11:24 PM
TbagzG35's Avatar
amsoil oil an filter all the time
__________________
2004 Graphite Coupe!! 6Speed! Couple of Goods, For now...
  #75
Old 11-18-2009, 10:30 PM
Wix makes the Napa gold filter. Fleet filters is where I get them and posted a thread about it. Same as the Napa gold and it's about $4.xx each. Alot better than $8.00 each!
definitely bought napa gold filter the other day and DEFINITELY PAID $8 not $4 :/ lol
Tags
102876, 2006, 51365, change, diy, engines, filter, filters, g35, mobil, nisson, oil, purple, royal, wix
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
