MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 04-17-2009, 06:58 PM
2005 Infiniti G35 Coupe
oil filter for g35
ive never changed the oil myself since i got my G. i alwayz took it to infiniti to get it done. now i'm trying to do it myself. i found a thread about what oils best for vq engine but never found any thread about what oil filters good. go with the oem filter from nissan? or get fram? or mobil 1? need ur input!
__________________
05 AT lakeshore slate coupe~debadged~jwt pop charger~TEIN H-tech~
Old 04-17-2009, 07:33 PM
Send a message via AIM to insydiusg35
I like using the K&N filter; it can can install and remove it via 1" wrench and I'm sure it's of high quality. On the other hand, I have heard that the Purolator oil filters are cheap and of good quality (can be purchased at Pepboys). I do recommend doing a search to find more details of each brand.
__________________
2004 OB COUPE 6MT / SEIBON / AVIC Z1 / WORK MEISTER S1 / INGS +1
Old 04-17-2009, 09:36 PM
2004 Infiniti G35
Wix 51356
from www.fleetfilter.com
Old 04-17-2009, 09:40 PM
SwivelHips's Avatar
Clean and Green
2003 Infiniti G35
^^ Great choice, that or Amsoil.
__________________
2003 Emerald Mist/Graphite || Z/Coupe springs||Rays 19s||Stillen CAI w/CF tube || Skunk2 plenum spacer || 350z-Middy || Stillen sways || Philips/PIAA 6000K || nismo shiny things|| AMSOIL syn fluids
Old 04-17-2009, 10:42 PM
Send a message via AIM to jutn35
this is oil filter thread # 23423432473294378374 ¼
but i use K&N or OEM
__________________
03G35cZtube bullsh*t tuna, nobody likes the as*hole here!!!!!
Old 04-17-2009, 10:46 PM
Purolator filter and Castor GTX conventional.
I change my fluid regularly and in short intervals by habit, so synthetic is not that cost effective for my needs.
__________________
2006 G35x Sedan // Black Obsidian/Stone // Premium C + NAV // Stock + 35% Tint/OEM Ipod integration kit //
Old 04-17-2009, 11:52 PM
BuckeyeInMI's Avatar
OEM Mod Squad
2005 Infiniti G35
Quote:
Originally Posted by uf20wop View Post
Wix 51356
Same part from NAPA
(Link Deleted)
Sorry, link failed (session timed out), but the NAPA Part # is FIL 1356
__________________
2005 Diamond Graphite G35x |OEM Z-Tube|K&N|HR Z Y|MD 5/16ths Cu ISO|Rev-up Airbox|SBD 10 Wire|Bump Clears-Blinker Mod|Coupe 18's|RE760 Sports|
Old 04-18-2009, 01:26 AM
2006 Infiniti G35
Send a message via AIM to BH818
royal purple oil and filter!!! I am using that next oil change I have on mobil 1 extended performance now. same price like $9 qt and filter is like $13
Old 04-18-2009, 01:28 AM
2006 Infiniti G35
more HP and torque with royal purple
see link
http://www.royalpurple.com/rp-videos.html
Old 04-18-2009, 02:48 AM
napa gold filter, great filter at a great value
edit: pretty sure the napa gold line is a rebadged wix, or is at least made by wix
__________________
2006 DG 5AT Coupe, sport, premium, aero, Stance GR+ Pro coils, SPC camber kits
Old 04-18-2009, 02:54 AM
mobile 1 m1-110, it's made for the M35, but it fits and it's longer=more filtering media...
also it's only $8at wallmart
__________________
Sedan - Totalled 4/27/09 - now an 04 coupe
Old 04-18-2009, 04:18 AM
Quote:
ya i'm getting royal purple oil. i didn't know royal purple made filters. i guess ill go with royal purple filters as well.
__________________
Old 04-18-2009, 06:34 AM
OEM Mod Squad
2005 Infiniti G35
That's what I thought too. Went to the Fleet Filter site, and they had a NAPA part #. They look the same, but had ever so slightly different specs on them. The Wix said 9-11 GPM, while the NAPA said 8-9. But every other spec was identical.
BTW, the Fleet Filter site and Wix site both list a different model for the G35. It's a 51365 instead of a 51356. The only difference is the 356 is slightly longer, so has more filter in it. But they do say the 356 will fit on an Infiniti, it's just not the one that comes up when you put your specific car info in.
EDIT: Just searched their sites again. The 51356 is for the 4.5L V8 from Infiniti. It fits the FX45, M45, and Q45. But it should fit the 3.5L as well since it's only dimensional change is length.
__________________
Old 04-18-2009, 10:15 AM
SwivelHips's Avatar
Clean and Green
2003 Infiniti G35
Quote:
Fits fine, I'm running that size with no issues. Also fits Maxima.
Here's the difference in size. The on eon right is the 51356 size, just happens to be an Amsoil:
__________________
Old 04-18-2009, 11:50 AM
2004 Infiniti G35
:werd:
the thread sizes are the same on the 365 and 356
they both fit the g but as the picture shows, the 356 is longer
Tags
102876, 2006, 51365, change, diy, engines, filter, filters, g35, mobil, nisson, oil, purple, royal, wix
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
