MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 08-09-2009, 01:46 AM
speeddream's Avatar
What are the symptoms of failing piston rings on our G's?????
I recently went through a compression test and my 03 6mt sedan scored: Left side starting from rear towards front cylinder 110, 110, 91 and right side was 95, 85, 80!!! And oem levels need to be ranging from 110-125 for our VQ'S. At the shop i went to they said im going to need piston rings and to take it to the dealer ASAP. I really didnt believe it, so then they also ran a leak down test and it scored red meaning bad on all cylinders. So there actually was a leak somewhere. I've never abused my G since i've had it. My G currently has 69,000 miles and it feels normal to me. Although i do have an oil consumption issue and yes its the VQDE not the REV-up. But i always made sure the oil level was where it needs to be. So if my piston rings are really failing, what are the symptons if there is any? Your personal imput is extremely appreciated. I will visit riverside as soon as i can.
Old 08-09-2009, 03:05 AM
speeddream's Avatar
Bump!!! Need info please. Found no similar threads.
Old 08-09-2009, 04:45 PM
Tollboothwilley's Avatar
2003 Infiniti G35
Probably the reason, at least in part, to your oil consumption. If the compression test shows low #'s like yours is...especially on the right bank, you are not getting the power output from the motor like you should be.
Stock warranty for powertrain is 5 yr. 70K miles. If you are still within warranty I would take it to the dealer.
__________________
Stillen Airbox | JWT Popcharger | Z-Tube | UR Light Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD Copper 1/2" Spacer | TB Spacer | Kinetix HFC | MD XYZ + VQ Resonated | Stillen Engine Damper | SPC Rear Camber | Stillen Sways | CircuitSport Tie Brace | 350Z Suspension
Old 08-09-2009, 04:59 PM
speeddream's Avatar
Dam...Well its been 6 years since 2003 and im under 70,000 miles still. I purchased my G at a nissan dealer and extended my powertrain warranty till 2011 or 100,000 miles. So i hope it works out.
Old 08-09-2009, 05:22 PM
OCG35's Avatar
Is that the new G39?
2004 Infiniti G35
Quote:
you have a Stillen hood but no SC... did the previous owner have a super charger?
__________________
Link to "My Garage" for info about the car
Old 08-09-2009, 05:31 PM
speeddream's Avatar
I actually had the stillen blower on once, but then sold it.
Old 08-09-2009, 05:42 PM
OCG35's Avatar
2004 Infiniti G35
were you burning oil?...
any chance the SC could have contributed?
__________________
Old 08-09-2009, 05:58 PM
speeddream's Avatar
Regarding the OC issue on my G, i found out about it since way before i had the blower on. I remember changing the oil my self and very little oil would come out. It had me thinking like, dam wth happened to the rest of the oil. At that time i didnt know about this sight and this is where i found that some G's had an OC issue and that we needed to chk our oil level constantly. But then that just appied to REV-UPS. But by the time i found out about the OC issue i had the blower on. So i kept my oil levels correct at all times even though my G was never my DD. And yes i did notice a more of a Oc issue with the blower, but like i said previously i never abused my G because i knew i was going to stick with it for a while so i wanted it to be in top shape. So the OC issue was since way before. Im thinking maybe during the time that i didnt know about it consumming oil all this happened. But my G feels normal though. Thats what is strange.
Old 08-09-2009, 06:18 PM
Canadian's Avatar
Canada, eh?
2006 Infiniti G35
Send a message via ICQ to Canadian Send a message via AIM to Canadian Send a message via MSN to Canadian Send a message via Yahoo to Canadian
Take it in for warranty asap! You should have taken it in as soon as you noticed there was a OC issue.
__________________
Relentless Autosports G35 Twin Turbo - Built 5AT - SGP Valve Body - JWT - Fast Intentions - Megan - NISMO - GReddy - Defi - Koyo - Nitto
Need cams? FS: JWT S1 Cams Brand New
Old 08-09-2009, 06:48 PM
OCG35's Avatar
2004 Infiniti G35
There reason I asked if you ever had a supercharger (thinking you might have since you had the hood) is because of the chance of running a lean condition, which could have contributed to the piston ring damage.
Its too late to deal with Stillen regarding potential cause from super charger… so I guess its all a moot point – I was just curious to know about the SC thinking it might have caused your problem initially.
__________________
Old 08-09-2009, 06:58 PM
speeddream's Avatar
I thought that to. The good thing is that im going to return my simple bolt ons to stock and take it to the dealer and see what happens there. You guy's imput and concerns are really appreciated. I havent yet heard of any g's with vq35de's getting replaced with new engines yet regarding a OC issue. Or have some ?
Old 08-09-2009, 06:59 PM
WhosUrBuddiee's Avatar
2004 INFINITI G35 Coupe
Oil consumption
__________________
National G Club G37S Bone Stock
Old 08-09-2009, 07:02 PM
speeddream's Avatar
Old 08-09-2009, 08:09 PM
OCG35's Avatar
2004 Infiniti G35
VQDE (but revups)... you can try to see if they will honor that... I'm not sure if there is an actual TSB, but if there is print it and take to your dealer...
__________________
OCG35's Avatar
2004 Infiniti G35
he hasnt been following the thread... I think he thinks its a quick easy answer...
__________________
Tags
bad, broken, burning, car, failing, leaky, oil, pistion, piston, problem, revup, ring, rings, sticking, supercharger, symptoms
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
