Help with camshaft position sensor
Old 09-02-2009, 05:42 PM
Mr. Uy's Avatar
Hi,
I am trying to replace my camshaft position sensor. I managed to get the bolt off that holds it in place, but now it is locked in a green plastic, that i cant seem to remove. I see that the clip moves up and down, but in either location it will not come loose. Anyone done this before? Any tips? Thanks,
Old 09-02-2009, 06:28 PM
darksideG35's Avatar
all you need to do is push in with a screw driver from the front until it clicks and then pull the plug off. I took a flat head screw driver, pushed on the green tab as shown in the picture and then pulled the connector off
Old 09-02-2009, 06:42 PM
Mr. Uy's Avatar
ya i finally got it, saw the same picture, had even done the same thing and it wouldnt come off, it was just super stubborn
Old 09-06-2009, 04:20 AM
Tollboothwilley's Avatar
Yup, can be stuck tight.
Old 09-14-2009, 03:11 PM
Mr. Uy's Avatar
Originally I got the SES, VDC and slip lights, and pulled the P0340 code. I had problems with the engine being hard to start, and what felt like a loss of power while driving. I had 6 codes appear on the OBD-II scanner, but they were all the same. I replaced the camshaft position sensor as i mentioned above. The "stalling" problem went away, but the car is still hard to start. I keep clearing the codes, but they keep coming back, but only 4 instead of 6, so it had to have fixed something. Car runs fine other than the starting problem. Any ideas?
Old 09-15-2009, 02:43 PM
jerseymike68's Avatar
useful sources here
Old 09-16-2009, 02:06 PM
What codes are you getting now?
Old 10-27-2009, 02:49 PM
Mr. Uy's Avatar
i am still getting four instances of the P0340 code, have a hard time getting around to fixing this, i read on my350Z that it sometimes may need the contacts cleaned with electrical cleaner, which i havent tried as of yet.
Old 11-24-2009, 01:29 PM
YourKuh's Avatar
F@#$! im dealing with the same issue now... going to autozone to get the part... the scan said the same code(s) as mentioned above..but it said its the driver side sensor.... where exactly is it located and is it a quick replacement or does it take awhile?
help guys ...
Old 11-24-2009, 01:37 PM
quick replacement. Just on the backside of the engine right by the valve cover. Easier to get to if you take off the upper/lower plenums
Old 11-24-2009, 08:11 PM
skyline250GT's Avatar
I had a similar problem on my Skyline 250GT (G35 sedan body with a VQ25DD motor). Hard to start and loss of power. Nissan replaced TWO camshaft position sensors and the problem was solved. Does the VQ35DE run 1 or 2 camshft position sensors?
Old 11-24-2009, 10:25 PM
YourKuh's Avatar
2 i think. passenger side (straight) drivers side (angled)
Old 11-26-2009, 12:38 AM
YourKuh's Avatar
got the sensor swapped out, took about 10min
...ECU reset...
she runs great.
Old 11-26-2009, 01:04 AM
What are the symptoms you guys get with that engine code?
Old 11-26-2009, 12:53 PM
YourKuh's Avatar
the car would die on me at stop lights... hard time starting the car ( it tries but keeps attempting to turn over) kinda sluggish ... and sometimes while driving it had a hiccup while cruising.
Quick Reply: Help with camshaft position sensor
