MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 10-14-2009, 07:16 PM
Gears 1-4 shift fine but when I get to 5th it's like I'm in neutral... :(
I drove the car to Jacksonville, FL on Sunday (10/11) which is about an hour drive. My car was perfect, not a single problem.
The next day, I was driving up to Charlotte, NC which is about a 4.5 hour drive and my car starting acting weird. While I was going about 85 the RPMs all of a sudden just revved all the way up and the car wouldn't accelerate. It wasn't slowing down either though. It was like if I barely pressed the gas it would accelerate slowly but if I pushed it at all it would just slip right by and rev up.
So, I started using the speed shifter and found out that it was only the 5th gear that was doing it. 1st, 2nd, 3rd, and 4th worked like normal. I drove in 4th the rest of the way to Charlotte, NC.
The whole time that I was there I didn't do much fast driving so 5th gear never gave me any problems so I thought *maybe* the problem disappeared. Wrong. One the way home it did the same thing so I had to revert to the speed shifter again.
I say 1-4 worked perfectly but maybe I felt a few small hard shifts but it could of been nothing. Nothing real noticeable at least.
One thing I do need to mention is that one the ride up my debit card wasn't working so we had to pay cash to fill the car up. I've owned the car for about 8 months and have only used Premium Fuel for it but this time we put in Mid-grade gas (89 octane). That shouldn't of caused this right?!?!
Please help.
Thanks.
__________________
http://SafeBluCigs.com/ Cigarettes you can smoke anywhere. Real Nicotine.
Old 10-14-2009, 08:52 PM
HomieG35's Avatar
Send a message via AIM to HomieG35
Sounds like it's slipping in 5th to me. Hope you're still under warranty...
Check your transmission fluid first! Make sure it's not burnt (black) and at the proper level.
__________________
SenBou.com| ProCharger : TurboXS : Data System : Seibon : Toyo : Valvoline : DEFI : Ro_Ja : SGP Racing : Dip-Tech.net
Old 10-14-2009, 09:48 PM
Nope, out of warranty. 6 years or 70k miles. Although I only have 66k miles on the car, 6 years ran out on September 18th, 2008. :\
__________________
Old 10-14-2009, 11:04 PM
HomieG35's Avatar
That's worst case. Best case is you can change the fluid and see what happens. I doubt it's ever been changed. I'm sure this is where people will begin chiming in....
IMHO... when the fluid in a transmission has not been replaced while the fluid is still "good", it's better to change half the fluid. Leave it half dirty, and refill to the proper level with clean. Drive it a few thousand miles, then do the same thing again until the fluid starts to get lighter and lighter- this is opposed to changing out all the fluid at once or getting it flushed. Don't take my word for it (or anyone else's) look it up and research it... hopefully this is your problem and not a slipping 5th gear!
__________________
Old 10-15-2009, 12:24 AM
i had same problem it was bad syncros
Old 10-15-2009, 12:42 AM
hyperlite21's Avatar
Send a message via AIM to hyperlite21
any mods? i had a high flow cat go out and it did the same thing
__________________
SxExCx-HKS-CRAWFORD-TEIN-MOTORDYNE-NRG-JWT-UTR-GIALLA-RICHIE-STILLEN-AXIS-FALKEN-V LEDS-06'PROJECTORS-PITHON-NISMO
www.myspace.com/mikeyfranco
*Team OCG's*
Old 10-15-2009, 05:07 AM
pfarmer's Avatar
I would do the fluid change and not sure if this applies but a transmission filter change.
I had something strange happen to me with my 08. According to a tech there is an issue if you are going something like 51 mph and floor it. In my case I was changing a lane when a truck also changed behind me and was travelling a lot faster than I was. I was worried about getting hit and I floored it. What happened next was worst then if it had stayed in high gear. Basically what occurred is nothing more than an increase in RPM with little to no increase in speed. According to the tech there is some sort of logic at 51 mph that allows the transmission to shift down to 2nd gear. It seems like the transmission simply started shifting downward until 2nd gear was reached. Not too happy about this situation.
In your case I would try the fluid and filter change and hope for the best.
__________________
Eagles may soar but weasels don't get caught in jet engines
Old 10-15-2009, 09:08 AM
Quote:
Only mod I currently have is a Fujita SRI.
My car has 66,800 miles on it and I just found out that I missed my 60k mile service. I'm going to take it by the local Nissan stealership today and see what they have to tell me. e they have some good news.
__________________
Old 10-15-2009, 09:18 AM
you probably have low fluid which caused problems engaging 5th. The big issue now is that you probably burnt 5th so it's rebuild time. You could keep driving in 4th until you get the money to fix it...I've done it on a grand prix and drove without a gear for months...lol.
__________________
2003 G35 DP Coupe 5AT
Old 10-15-2009, 12:26 PM
Quote:
Awww, don't tell me that. I'm just now getting the money for modding and now I have to rebuild the transmission?!?!?! Bogus.
__________________
Old 10-15-2009, 06:17 PM
Took it to a Nissan dealership today. They hooked the computer up to it and said that it wasn't throwing any codes. They also left the computer hooked up while they drove it and said they can't find anything wrong.
They haven't driven it over 75mph yet though. I told them to get it up to about 90-100mph and see what they find out. I can't believe it didn't throw any codes though? wtf?
They just called me and said that they want to check the transmission fluid level but they don't have a dipstick that will fit. They tried to locate one but were unable to.
Any ideas where I can find one? Thanks.
Old 10-15-2009, 10:01 PM
But it shifts into 5th now? If it does...then PLEASE stop driving the car unless absolutely necessary intil you find out what is wrong. Intermitent clutch application can cause the clutches to burn really badly.
__________________
Old 10-15-2009, 10:05 PM
Locksmith's Avatar
SPONSOR
2004 Infiniti G35
Send a message via AIM to Locksmith Send a message via MSN to Locksmith
Hmmmm not sure if this is the same issue but I had a problem where I could barely get my shifter into 5th gear and eventually Nissan figured out that my bolt had come loose that connects the shifter under the car to the piece that actually changes the gears and all they did was tighten it and it fixed it right away. Not sure if its the same issue you're having but thought i'd chime in with my story.
__________________
*NIFTYSHIFTY ShiftBoots* Need a new shiftboot? PM ME!!!!!!!!WWW.NIFTYSHIFTY.COM
*We make boots for AUTOMATICS and 6mt's*Custom Armrests are also AVAILABLE!
Old 10-15-2009, 11:06 PM
HomieG35's Avatar
First of all, when I worked at an Infiniti dealer and if someone said the issue was happening over the posted speed limit- like 90-100mph we would tell them to have a nice a day. You shouldn't be reaching those speeds on a public highway anyway, and if the car doesn't act up until 90mph, then you shouldn't need to worry about it.**
Secondly, I know I've read some year models didn't come with a dipstick.. but it's amazing they "couldn't locate one". They should have everything there they need to service your car. If it was still under warranty would they have kept your car for a week while try to "locate" one? Find a new dealer. Referring back to point one, if they drive your car 100mph on a public street... find a new dealer.
Just because the car acts up doesn't mean it will throw a code. When the tranny slips in a manual car it doesn't throw a code... There have been a ton of instances here when a car is doing something really weird and no codes can be found.. stored or new.
**OK, I know... I know... "so why don't they just govern every car to 70mph?"... I'm not busting your nuts, and has nothing to do with "OMG HAx0Rz you shouldn't be skreet skracing!".. just telling you what a 'responsible' dealer would do.
__________________
Old 10-15-2009, 11:50 PM
I think some people are confused....I believe the OP has a 5at not a 6mt.
__________________
Tags
5th, auto, car, cars, cavalier, change, g35, gear, gears, infiniti, nissan, p1716, shift, shifter, transmission
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
