Throttle Body Coolant Bypass mod?
Old 10-18-2009, 09:32 PM
G35-31's Avatar
is this a goodthing to do for the g? and whats the main purpose?
Old 10-18-2009, 09:41 PM
rcdash's Avatar
prevents heating the throttle body/neck of plenum with hot coolant. Not needed in warm climates so you can run the plenum marginally cooler bypassing the coolant flow. Motordyne sells a kit...
Old 10-18-2009, 09:46 PM
G35-31's Avatar
cant you just make on yourself?
Old 10-18-2009, 10:02 PM
mesias's Avatar
Yes, you just need to bypass the TB. Connect together the two hoses that go to it and you are done. GL!
Old 10-19-2009, 10:04 AM
Q45tech's Avatar
Unfortunately the air at WOT is traveling so fast that it doesn't have time to heat up from the walls of TB or plenum.
If you can develop a method to actually drop air temperature 11F it might be worth 1% density increase.
A cold plenum can condense more PCV gases/oil vapor after throttle plate making things dirtier and risk thottle sticking.
Old 10-19-2009, 04:38 PM
OCG35's Avatar
this is true... as I've noticed with excessive build-up (I clean it every so often)… for this reason a “control” valve like Motordyne sells is a better option than completely bypassing… I run with mine open for a while every now and then.
However, a good oil catch can should keep the "PCV oil vapor" to a minimum.
Old 10-27-2009, 10:31 PM
TbagzG35's Avatar
not gd in cold weather
Freeman186
09-06-2023 10:07 AM
esotericrider
Northern California
09-10-2015 02:28 AM
Chadwick Arnold
09-09-2015 02:59 PM
INVADER_6MT
09-03-2015 01:47 AM
Quick Reply: Throttle Body Coolant Bypass mod?
