Feeler: SxExCx V2 Grounding Kit (STEALTH)
#61
I think this is a legit issue to be raised whether here or on grounding kit threads.
If I'm selling a product (e.g., a new pain medicine, new technology, improved methods for building muscle mass or losing weight) that many claim produces certain results, and others dispute it, then it's incumbent on me to produce evidence to its' efficacy.
Any respectable business will do this to have long term success w/o having others intervene on their behalf.
Also anytime you have more than two conductors on the same grounding bolt you have a at least one at a different potential than the outside two, in the example above you will see at least 3 of these cases. Different potentials mean circular currents. Use of grounding blocks help to avoid this situation which is common with ring style connector ends. As far as sensors being helped in most cases on the Infiniti you should see little difference. The example below is basically speaking about audio connections similar to the the Infiniti but also applies to most of the sensors on the Infiniti as well which are balanced to avoid noise introduction.
http://www.dplay.com/dv/balance/balance.html
Differential grounding can induce noise. In the case of balanced lines you will see an attempt to avoid this possibility by the fact that often times only one end of the shield is grounded.
Of course if your stock grounds are defective then you may see some improvements.
Many have seen benefits by simply fixing defective stock grounds and doing what most grounding kits have you do after installation - resetting the ecm. Resetting your modules will usually make the car feel different after doing so even if you don't replace or repair any of your wiring.
Also in the case of electron flow it is actually the reverse of current flow, a fact that may have driven the introduction of positive grounded cars (with possible corrosion issues). If increasing the size of conductors it may actually make more sense to increase the size of the positive since this is your actual return path. You are not going to increase system current flow capacity by increasing just one leg if the remaining leg is the same size as the original opposite leg.
Perry
#62
I drove ttrank's car solo
Received 1,486 Likes
on
#64
on
#66
#69
