G35 ticking noise? help and suggestions?
So guys I have the same exact f*ing problem. Been doing a lot of research.
Ticking noise 100% of the time. 2 Nissan mechanics said the Boise is from lifters caused by low oil pressure at some point of time.
For me, I know the problem started when I switched to synthetic oil. Started changing oil every 5000 miles instead of 3000 with regular. All these 3.5 litter engines burn oil. You do not want to use synthetic. Now I put in extra oil every 1500 and it helps some.
Question: am I **** out of luck and just have to put up with the rattling sounds? I am not willing to take apart the engine to get to the timing chain, because the cost is almost the same as an engine swap (I read). At that's point read: new car.
Thanks
Thanks
Thanks
Thanks
Fact is, is that cars are designed for the specific recommendations put forward by the manufacturer. The reason for the conventional oil recommendation is an issue of valve clearances. When you use synthetic in the VQ, it will almost always create a valve noise problem.
I drove ttrank's car solo
Received 1,486 Likes
on
Urbanengineer (11-27-2016)
