Check Engine Light on...got the code P0420, what should I look for?
Old 10-27-2010, 03:44 PM
KingCobra's Avatar
So the check engine light came on, so I used my Actron Scanner and found the car is throwing a P0420 code...
From the site:
"Code P0420 indicates that the exhaust gas exiting the catalytic converter is too similar to the exhaust gas entering the converter. A faulty or overloaded converter due to an unbalanced air/fuel mixture can cause this condition."
Anyone else have this code with our cars? What should I look for?
Thanks!
Old 10-27-2010, 03:58 PM
KingCobra's Avatar
By the Way, my car just passed the 90k mark....could it be the cats?
Old 10-27-2010, 10:22 PM
Tollboothwilley's Avatar
P0420 is for catalytic converter efficiency
Either the CAT is bad or the O2 sensor - my money is on the O2 sensor.
Old 10-28-2010, 05:10 PM
KingCobra's Avatar
The scanner checks the o2 sensor and it says it passes the test fine....weird...either way I reset the ecu so im waiting to see if it comes back up
Old 10-28-2010, 05:11 PM
KingCobra's Avatar
Also, how bad is it to drive around if the o2 sensor is out? Could it mess up my car?
Old 10-28-2010, 07:03 PM
LMG_35C's Avatar
Scanner is saying that the sensor reading / resistance is within range, not that it's reading correctly. A lot cheaper to replace sensor than the cat.
Driving with a bad sensor is going to effect emissions and probably fuel consumption. That code is for Bank 1 (driver I think), you could swap sensors and see if the problem follows... then you'll have a better answer.
Old 11-03-2010, 05:54 PM
KingCobra's Avatar
Thanks LMG....how hard is it to change the sensors? Can I do it with basic tools?
Also, I would basically have to buy 2 new sensors and if its not the sensors then im stuck with the ones i bought...
Should I just replace the Cat? I was thinking of going hi-flow cat either way....
Old 11-04-2010, 12:11 PM
HangUp n' Drive's Avatar
Leaks can cause this fault also. The O2 sensors before the cats control the A/F mixture.
The O2's after the cats verify converter operation.
Muski_G
12-01-2023 11:11 AM
Jay 21
08-05-2015 04:53 PM
ClwMike
07-23-2015 12:55 PM
igking
07-19-2015 01:12 AM
Jadenkid22
07-14-2015 12:33 AM
Quick Reply: Check Engine Light on...got the code P0420, what should I look for?
