Can anyone identify this sound?
The chain is inside the front cover and you can't see it. There are two serpentine belts, which I think jooky is referring to.
Look directly down you should see two black belts in the engine bay.
Yes, it can be serious if your main serpentine belt breaks you'll lose your power steering and alternator. The car will be hard to steer and then you'll be running off the battery and the car will eventually die.
The following 2 users liked this post by coffeysm:
Atad (01-08-2014),
jookyshank (01-07-2014)
