Coil Pack bolt hole
Coil Pack bolt hole
So I tackled my spark plugs yesterday at 86k. Went to put on one of the coil pack bolts back in and it squeaked the whole way in. It ended up being stripped out. The bolt itself is fine but not the bolt hole. I always start my bolts off by hand and get them going. Will they cause any issues not being tightened down?
rsingerG35 (02-04-2014)
Ended up installing a helicoil so I could tighten my coil pack again. I drilled out the old threads, tapped new ones, and installed the insert. After it was done I was able to torque it down nice and snug.
One thing I had to make sure and that was not drilling through the valve cover. lol.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
03-10-2018 11:38 AM
