APS TT Engine
APS TT Engine
Small tidbit of background.
My buddy bought a Z with an APS tt kit and pulled the engine to refresh gaskets and new clutch. Drove it into some water and most likely bent a valve. Also killed the tranny (synchros for 3rd are done) and clutch was toast. Engine ran beast and will still fire up and run. Has been sitting since before winter..
I have a G sedan, same non-revup vq35 as his Z.
Now, im possibly going to take the Z off his hands and swap motors (fixing the head and new clutch of course)..
Im sure everything will fit in the bay but my only concern is if the intercooler piping can be routed the same as in the Z and will the ECM be compatible with the wiring harness on my G. Is my best option to have the piping fabricated to fit the G and have the ecm tuned to accomodate the new engine?
Positive input would be appreciated. Thanks
Yes, engine was built by APS some years ago. We tried searching for a build thread and couldnt find anything. Im sure its out there somewhere.
To take the kit off would be just enough, if not more, work than just swapping them.
Both have the same mileage but the Z engine does have stronger internals and tons of other goodies.
would my transmission hold up to it? has 160k, previous owner babied it and commuted about 40 miles a day on highway for a while
ok, update on this. my buddy has kept the Z and its been sitting a while.
Ill likely get the tt kit from him. everything included: manifolds, dp, wg, bov, turbos, i/c, piping, injectors, aps piggyback, fuel pump, oil pan, and other misc items.
could i install this on my engine and have about 300-320 reliable hp?
Freeman186
09-06-2023 10:07 AM
AuAltima3.5
09-13-2015 10:53 AM
