Driver camshaft and bank 2 solenoid
Old 02-26-2014, 01:21 AM
The_Silencer's Avatar
My 2005 G35x driver side camshaft sensor supposedly went bad. Symtoms include hard starts and my car suddenly stalling in the middle of the road so i replaced it with a sensor from rockauto. This cleared the SES light and I had no issues driving 500km to Detroit and back. about a month later the SES came back on and sometimes the SLIP and VDC light would come on. Error code p0345 came on again. I decided to replace it with a new one I bought directly from a Nissan dealership. After installing it the SES light comes on and error code 0021 comes on. I swapped back the rockauto sensor and it'll drive fine for a bit before the p0345 codes comes on. Swapping back the Nissan camshaft sensor results in only the p0021 code popping up. Does the bank 2 solenoid really have an issue or is the camshaft sensor from Nissan at fault? I'd really want to solve this issue soon since I'm overdue for an emissions test.
Old 02-26-2014, 01:29 AM
hurleyguys's Avatar
Check your oil level first, if it is low top it off and reset the SES. otherwise i would assume a bad solenoid.
Old 02-26-2014, 11:06 AM
I just find it strange that the p0021 code never shows up when I was using my Rockauto camshaft sensor, only with the OEM one does it show up.
Old 03-01-2014, 06:56 PM
I bought a genuine NIssan driver side camshaft sensor and that fixed the issue. despite the fact that the code is for the solenoid, it was purely the driver side camshaft senor that was the cause.
Old 04-23-2018, 12:36 AM
salena1973's Avatar
trouble code 0021
I first got the 0345 code and I replaced the camshaft position sensor bank 2 so I replaced the sensor and now I get the 0021 code. The car is running fine, its not missing and it idles at 700 rpm, it doesn't stall. Please tell me what I should do first, I already changed the oil. Do I need to check for low oil pressure? What is my next step.
Old 04-23-2018, 11:24 AM
cleric670's Avatar
BANNED!!!
Received 2,456 Likes on 2,150 Posts
Coupe 6MT Premium RAS
What year G35. On the DE motor it's typically the cam actuator solenoid isn't working properly (if you are CERTAIN the phase sensor works, if you used a non-OEM one I strongly suggest getting the actual Nissan sensor). It's driven off oil pressure so you should definitely check your oil level to make sure you're not low, these engines usually consume oil. If you have the HR motor it's usually the gasket for the cam solenoid because it's made out of paper and is frequently known to blow out thus causing pressure to drop and not advance the cam properly.
I also recommend getting your battery and the cables cleaned up on it since this is just a big computer and electrical resistance screws things up as well.
chinee
04-19-2021 09:18 PM
Joshua615
08-31-2015 12:29 AM
newg37
07-26-2015 09:32 AM
Thaaa_king
07-18-2015 05:56 PM
Quick Reply: Driver camshaft and bank 2 solenoid
