seeking your advice on 2005 G35 5AT differential swap
Old 03-19-2014, 08:30 PM
onlyhuman's Avatar
hey guys, I'm will be doing a differential swap on my 2005 G35 5AT. My car currently has an open differential with a 3.357 gear ratio. I'm hoping to get your experience. There are a few local scrap yards that I could pull a complete differential from. I can either get a VLSD 3.357 for $100 or a VLSD for 3.538 for $250.
For those who have done this swap in an 5AT, was it a noticeable improvement between the 3.357 and 3.538 gearing? Does this change effect the speedometer? Appreciate any advice!
Old 03-19-2014, 08:32 PM
Hotdawwgman's Avatar
I always thought our cars came stock with a 3.5... I hear the 3.9 is amazing! Just won't get the best fuel economy on the freeways
Old 03-19-2014, 09:27 PM
herrschaft's Avatar
The difference between a 3.3 and a 3.5 is small but still noticeable. I believe only the 06+ had speedometers that were effected. Go with the 3.5
Lucky74 (04-04-2014)
Old 03-20-2014, 03:44 PM
onlyhuman's Avatar
maybe I should look at stepping to the 3.7 from a G37. I'm not too concerned with gas mileage... unless of course it's a big drop. Has anyone tested their mileage before and after a 3.3 to 3.7 swap?
Old 04-02-2014, 07:40 PM
GoldG35's Avatar
im planning to buy an vlsd from a 06 350z manual my car is an g35 07 5 at is this will fits without any problem cause of the manual and 5at ?
Old 04-02-2014, 10:05 PM
herrschaft's Avatar
It will fit
Old 04-02-2014, 10:22 PM
GoldG35's Avatar
K but whats the differance betwene the 6 mt vlds and 5at vlsd?
Old 04-02-2014, 10:24 PM
herrschaft's Avatar
Depends on the years. The diffs from both the G35 and 350Z all have the 4-bolt flange, therefore they are interchangeable.
Old 04-12-2014, 02:29 AM
onlyhuman's Avatar
I found a 3.5 VLSD differential locally for $95 so couldn't pass that up! I replaced all the seals and inspected the gears, it's in very good condition. I just swapped it out tonight. I was alone, so I bolted some plywood to my floor jack for a lift. ha! It actually worked great! I didn't remove the exhaust, and only removed one side of the sway bar to move it back a little. The entire swap took just over 3 hours.
[IMG][/IMG]
Old 04-12-2014, 08:50 AM
Shawno72's Avatar
[IMG][/IMG]
Let us know what you think
Old 04-13-2014, 11:02 PM
onlyhuman's Avatar
The car definitely feels a bit quicker. I can feel the traction with the VLSD when taking off hard. A more than worthy swap!
Shawno72 (11-13-2014)
Blakelyg35
08-15-2015 12:12 PM
laksjd84
08-03-2015 05:33 PM
lemmy999
07-25-2015 12:13 PM
AustinErkl
Drivetrain
07-18-2015 05:44 PM
Scredeur4
Steering & Suspension
07-17-2015 06:30 AM
Quick Reply: seeking your advice on 2005 G35 5AT differential swap
