Help please!
Help please!
Have an 03 g35 sedan 5at.
ok... I dont know if it is supposed to do this but......
I can feel all the shifts, sometimes a little rough, and after a shift its almost as if someone applied the brake and I lunge forward a bit.
When going 50-60 mph or so ....if I let off the gas the rpms will drop to 1k until I press gas again....(do not know if this is normal)
then other times I let off the gas and it rides the rpms all the way down until it downshifts.
I do not know automatic trannies that well, someone please let me know if these occurrences are normal. Thanks!
Huh? Rpms and speed should drop together evenly. If your rpms are falling off harshly, then no, that's not normal. You need to check your fluid tho. What do you mean no dipstick? Is it gone?
but iirc at higher speeds (5th gear, 2500+ RPM) the converter locks up for sure.
And the RPM drops occur if you're doing a lower speed (4th gear, 1800RPM) something like that. Although if you hammer it and then let go. It rides down the RPM.
If you're in manumatic mode, Idk. It works a little differently.
Thats awesome! Thanks for the info, I was starting to trip lol. Checked fluid and it looked beautiful, not burnt or anything. The tech said that he had an 03 coupe 5at and it feels like it is slipping sometimes (for whatever reason) but its not, he said the harder you drive it the easier it shifts lol. And I have found this to be true, definatley a finniky car but I love it. I let go of a supercharged 06 mustang gt for this, ( more comfortable to drive everyday)
And I did some more testing. from gears 1 - 3 it does a drop to 1.1kish if u stop the gas, then when you press it again it goes back up accordingly. In 4th/5th it doesnt drop as much, maybe like to 1.5 but it's not so sudden since it's higher than 1.1. Unless if you're on highway speeds then it locks up. Idk why the transmission does it, but I dont wanna bother wrapping my head around it. It's working, that's what matters.
