Need to remove fuel from gas tank. HELP HELP
Car has sat for about six months.
Is there a way to make fuel pump run full time till gas is pumped out?
Its impossible for me to get my fat azz under the car to stick a hose in the tank... no jack to lift the car higher.
The "fsm" only give to ways to do this.
1) use fuel pump
2) use a hose
Could just pull the fuel pump but i dont won't to go that route just yet.
1) use fuel pump
2) use a hose
Unfortunately there are two tanks to empty.
Pull up the back seat. There are two access panels under there. You need to empty both tanks, doing one won't suffice.
Buy a boat bilge pump, one of the hand powered ones. They are red/white/clear. Open up the tanks then pump it by hand. It doesn't take long. Just did it.
Danielek
05-01-2022 01:28 PM
Mad A
Not G35 Related
12-08-2015 01:45 PM
Rhinos7777
09-06-2015 05:36 PM
