Knocking noise in park and neutral only
I drove ttrank's car solo
Received 1,486 Likes
on
I work at a used car dealership and we had a similar issue with an early 2000 model Tahoe. We thought it was a motor knock so we replaced the motor. Started it up and it ended up being in the trans. Not saying 100% that's what it is. But I would definitely look into it
Edit: Also depending on the what type of knocking you're talking about, it could be a worn motor mount
