MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 05-01-2006, 08:42 PM
Andy2434's Avatar
Quote:
Originally Posted by DaVeeD
BTW is this for modded VQ's or is this suggested for stock VQ's as well?
This simple mod is all engines regardless of mods.
Old 05-01-2006, 09:06 PM
Florida G35 Club
If you look at where the oil pools, in the plenum. Its scary to me on a N/A engine that may be road raced or drag raced in the fact" that the oil will move to the back runners and just dump or be sucked up in the cylinders. Oil will drop octane big time and then death rattle accrues, ECU pulls timing, nothing here is positive on a performance stand point. On a F/I engine the problem is 20 times worse because of the cylinder pressures and blow by the ring gases.The PVC valve is over whelmed with blow by gases and oil in most modern day engines. Have you ever wondered why damn nearer all TT have lost number 4,5,6, cylinders when the engine blew. Oil and gas do not mix well in a combustion chamber. There is a 100% fix for this problem, and in time when Tony can put it together, will be one of his biggest Mods. Maybe I should get off my *** and start putting some good mods together.
Oil control is so very important in making Horse power. This filter" separator" fix sure helps some of the issues. Great little mod,
Old 05-01-2006, 09:35 PM
GLuXuRy's Avatar
Send a message via AIM to GLuXuRy
can we sticky this?
__________________
mmm ... i dunno how much i lowered my car
Old 05-01-2006, 09:42 PM
Msedanman's Avatar
O.F. Administrator
2008 Lexus IS-F
Send a message via AIM to Msedanman
can we sticky this?
Done....
C.
__________________
MSM
Old 05-01-2006, 09:58 PM
GLuXuRy's Avatar
sweet thanks
__________________
Old 05-01-2006, 10:01 PM
GLuXuRy's Avatar
Ok lemme get this straight.. all this does is prevent oil getting into your lower plenum.. which will result in oil getting into the combustion chamber.. in result mess up the VQ in the long run correct? Is it easy to go back to the stock way also?
__________________
Old 05-01-2006, 10:16 PM
Andy2434's Avatar
Yes, yes and yes . . .
If you use the stock hose clamps for the connections at the PCV and lower collector connections . . . You can remove this entire assembly witnin seconds and reinstall the original piece of hose is seconds, as well. Removing and replacing this mod was a big consideration.
Old 05-01-2006, 10:18 PM
GLuXuRy's Avatar
sweet thanks for the info andy !!! Ill be doing this either tomorrow or later this week
__________________
Old 05-01-2006, 10:20 PM
GLuXuRy's Avatar
ok again another question... i know this will prevent oil from entering in the "FUTURE" but what about the oil thats already in the plenum (if any) will it just burn off in the future?
__________________
Old 05-01-2006, 10:26 PM
Andy2434's Avatar
Unfortunatlely, the oil already in your lower collector will eventually get sucked into the intake runners. You can open the plenum up and wipe away the residual oil, if you wish or just leave it. The important thing to remember here is that we are attempting to minimize the amount of oil vapor which gets deposited into the lower collector, if not eliminating it all together.
Old 05-01-2006, 10:32 PM
GLuXuRy's Avatar
K.. i think ill wait till i get a spacer or mrev... i have the tools to do it but ill just deal with it now... one more question... my friend is going FI (vortech)... would this be too small of a catch can for him? Should he get a greddy/stillen one or could he use this?
__________________
Old 05-01-2006, 11:09 PM
Send a message via ICQ to G35_TX Send a message via AIM to G35_TX Send a message via MSN to G35_TX
This is awesome Andy. I will be making a trip to HD or somewhere to get this kit.
__________________
2007 NISMO 350Z - Dynojet: 293.22 rwhp, 247.77 rwtq / UPREV Osiris / Motordyne Dual Shockwave Ti rolled / Injen Dual CAI / Berk Metallic HFCs / Much More
2009 Z/G International Convention coming to San Antonio, TX (Sept. 28, 2009 - Oct. 2, 2009) Hosted by ZSPORT.ORG http://www.zcon09.com
Old 05-01-2006, 11:16 PM
There are bigger ones. I know sears sells a bigger one for the compressors that are actually glass as well. But your going to pay more money for those.
Or just go with the catch can if you can locate a good place to mount it.
__________________
Old 05-02-2006, 01:04 AM
Andy2434's Avatar
Quote:
LOL . . . I owed you one for the things that you have posted, which helped me, Russ.
  #30
Old 05-02-2006, 01:34 AM
Always good to help each other.
__________________
Tags
air, catch, circular, compressor, depot, dimension, filter, fuel, g35, greddy, hda70403av, hda70600av, home, hose, husky, makeshift, oil
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
