Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
♦ G35 Plenum Spacers Offered at Concept Z!! - $1 Shipping!! ♦
Old 07-25-2011, 11:37 PM
Coz@Czp's Avatar
$1 Shipping in the USA!!
_________________________
CZP 9.5mm G35 Plenum Spacer VQ35DE 03-06 350Z
Description:The CZP Billet Aluminum 9.5mm (3/8) Plenum Spacer is a direct bolt-on for easy install. The original plenum tapers at the front cylinders to clear the front strut bar, causing reduced airflow. The CZP plenum spacer raises the top plenum for maximum airflow to the front cylinders. Strut Bar spacers are included to clear the raised plenum height. With more airflow thought the entire upper plenum, HP gains from 10-14 can be achieved.
Kit includes
- 9.5mm (3/8) Billet Aluminum Plenum Spacer
- Self Adhesive Thick Gaskets, for a secure seal
- Installation Hardware Kit
- Strut Bar Spacers
AAM Spec Angled Intake Plenum Spacer VQ35DE G35
Description:The AAM Angled Plenum Spacer for the G35, 350Z & FX35 is the ultimate upgrade in the quest for more power. The billet aluminum spacer sits between the factory upper and lower plenum, creating a larger volume to rush towards the cylinders. Power gains across the board. The upper RPM range opens up considerably. You get to keep your factory engine cover, your factory strut bar (350Z) and gain 10-15HP in under an hour. 2006 350Z/G35 gain between 6-10hp on average.
Motordyne Engineering G35 5/16 inch Basic Plenum Spacer
Description:The Motordyne Iso Thermal plenum spacer adds 12HP-14HP. It can reduce the heat transfer and heat soak by thermally isolating both the upper and lower plenum. 5/16" thickness provides the best overall performance without compromises. This kit is fully compatible with your engine cover and strut bar. All Motordyne Iso Thermal systems keep your upper and lower plenum cooler without the risk of throttle body freezing when driving in cold weather.
Motordyne Engineering G35 5/16 inch Iso Thermal Plenum Spacer
Motordyne Engineering G35 5/16 inch Copper Iso Thermal Plenum Spacer
PM me for best pricing or with any questions.
Old 07-27-2011, 03:33 AM
Coz@Czp's Avatar
Bumped
Old 07-29-2011, 04:13 AM
Coz@Czp's Avatar
Bump!!
Old 08-02-2011, 07:32 PM
Coz@Czp's Avatar
Bumped!!
Old 08-04-2011, 09:47 PM
Coz@Czp's Avatar
Bumped!!
Old 08-07-2011, 03:40 AM
Coz@Czp's Avatar
Bump!!
Old 08-07-2011, 12:07 PM
MADtotheA's Avatar
md 5/16 iso thermal shipped to 29715. thanks
Old 08-07-2011, 02:52 PM
Coz@Czp's Avatar
Just click on "add to cart" of the kit you're interested in to get a total w/ shipping.
Kz_Ed
19 Inch
10-16-2015 10:32 PM
laksjd84
08-03-2015 05:33 PM
Ninjay16
07-20-2015 01:21 AM
RAVSPEC
Wheels & Tires-Vendor
07-16-2015 01:58 AM
Quick Reply: ♦ G35 Plenum Spacers Offered at Concept Z!! - $1 Shipping!! ♦
