Stillen Authorized Dealer: Supercharger Kits - Engine Dampener - Intakes & More!!
Stillen Vendor: Supercharger Kits - Engine Dampeners - Intakes - Z-Tubes & More!!
_________________________
Stillen G35 Hi-Flow Intake 03-06 Sedan, 03-07 Coupe
Description:Cold air is in, and STILLEN can supply your G35 coupe or sedan with plenty of it. Long known as the leaders in Nissan/Infiniti performance tuning, STILLEN has introduced a Cold Air Intake System for the popular G35 coupe and sedan. Due to the different states of tune of each model, the intake adds 11horsepower at 6,100 RPM to the G35 Sedan and 5 ponies at 5,700 RPM to the Coupe.
Stillen G35 Hi-Flow Intake with Z-Tube Package 03-06 Sedan, 03-07 Coupe
Stillen Generation 3 Ultra Long Tube Dual Intake Kit G35 07-08 Sedan, $1 Shipping
Stillen Twin Intake Kit Polished Long Tubes 07-08 G35 Sedan and 08+ G37 Coupe
Stillen G35 03-04 Super Charger Kit Stage 1
Description:
• The Most Reliable Forced Induction for the VQ engines.
• Choose Your Power - Four stages available
• Quiet Operation, no Whistle. Powerful, Reliable and 50 State Legal.
• Comprehensive Instructions - Average Install Time of 12 Hours
• The Only 50 State Legal Supercharger or Turbocharger for the VQ35 Engines (Stage 2 only)
• The Only Supercharger or Turbo Kit with an optional 3 year / 36,000 mile engine warranty (Stage 2 only)
• The most mid range power and torque - no one else comes close.
• Available in black or polished finishes (additional cost for polished).
• Delivered Fully Tuned for Your Vehicle.
• Sophisticated Fuel and Timing Management.
Stillen 350Z/G35 Engine Dampener Brace
Description:When an engine moves excessively in its mounts, energy is wasted. Stillen's engine stabilizer converts this wasted motion into forward momentum. An isolastic mount acts as a shock absorber and dampens unwanted motion. With no hydraulic parts to wear or fade in use, this is a long term solution. Easy mounting uses existing holes and complete instructions are provided.
Stillen G35 Brake Master Cylinder Stiffener 03-05 Sedan, 03-06 Coupe
Description:Open the hood on your G35 and have someone step on the brakes. You'll see the master cylinder dive towards the frame. This hurts your braking performance & softens up the brake pedal. Our Master Cylinder Brace supports the cylinder and translates that wasted motion into braking force. You'll notice the improvement immediately. This brace consists of a adjustable red anodized billet aluminum piece with a delrin support cup and CAD plated mounting bracket and hardware.Note: **This will not fit 06 G35 Sedans. On 05-06 Coupes, the master cylinder must be 6", this will not fit 3.5" master cylinders.*
Stillen G35 Grounding Kit 03-06 Sedan, 03-07 Coupe
PM me for best pricing or with any questions you have.
Description:
Last edited by Coz@Czp; 02-01-2016 at 06:17 PM. Reason: Stillen Vendor: Supercharger Kits - Engine Dampeners - Intakes - Z-Tubes & More!!
