TUNERZ STORE | UpRev Engine Management Solutions
Quick Overview
Popular data logging and diagnostic tool for today’s Nissan and Infiniti vehicles. Cipher allows you to connect your USB equipped Windows PC directly to your vehicle and communicate with on-board systems such as the ECU.
With Cipher, you can log various sensors/parameters and retrieve DTC (Diagnostic Trouble Codes) so you can see how your vehicle is running and see what needs to be repaired or adjusted. Data that is retrieved with Cipher can be viewed in real time or saved to a file for later viewing or comparison. Cipher’s .csv files can be viewed through Cipher’s built-in graphical display or through many spreadsheet programs.
More on Cipher
Cipher communicates using Nissan’s proprietary communication protocol which enables you to view data with more speed than generic OBDII scan tools giving the user better insight into how the vehicle is running. Sample rates of 20 times per second can be achieved on more than 15 sensors at a time.
Simple ECU and BCM Control
Cipher also provides the user with basic dealership work support routines for the ECU and BCM including:
Target Idle RPM
+/- 2 degree static timing adjustment
Cylinder power testing
Clear Learned Fuel settings
Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
Fuel Pressure purge
Ethanol Adjustments (if vehicle is equipped)
Coolant Test
Supported Parameters:
Below is a short list of available data parameters...
Engine Speed - RPM
Throttle Position Sensor
Vehicle Speed
MAF Sensor
Calculated Load Value
Oxygen Sensor
Ignition Timing
Accelerator Position
Wide Band A/F Voltage (equipped vehicles)
Coolant Temperature
Cipher supports most Nissan/Infiniti vehicles 2003 and newer. To see a list of fully supported vehicles please check out support page. Some vehicles may have limited functionality.
Quick Overview
Osiris Standard - PC based reflash system allowing the user to flash their ECU with customized tuning provided by UpRev or an UpRev Pro Tuner. Osiris Standard includes Cipher and comes with three eTune updates providing custom tuning for your vehicle.
Osiris Standard
Osiris Standard includes Cipher and utilizes the Cipher cable to reflash and communicate with the vehicle through the OBDII Diag Port. Osiris Standard also includes Map Switching allowing you to use different tunes for different situations and 3 eTune updates you can use at any time.
Osiris Standard is a licensed based system meaning your license will be transferred to the first ECU that is flashed. This vehicle can then be flashed as many times as the user wants, but the flash will not work on any different vehicles. One additional license can be purchased at a discount for enthusiasts that may have more than one vehicle, contact us for details.
Parameters that we will tune include:
Up to 5 Maps on cruise control equipped vehicles
Idle RPM
Speed Limiter
Electronic Throttle Control to achieve Wide Open Throttle at all speeds
Rev Limiter
DTC disable
AFR Targets
Fuel Compensation
Ignition Timing Advance
Cam Phasing for equipped vehicles.
Quick Overview
Osiris Tuner - For the do it yourself types who are familiar and capable of tuning their own vehicles or the enthusiast looking for a better alternative to Stand-Alone ECU and Piggyback systems. There is no tuning tech support included with the purchase of Osiris Tuner.
Osiris Tuner
The Osiris Tuner system includes Cipher, Map Switching, the flash utility and our powerful, new 2.0 ROM Editor. Osiris Tuner supports NA applications and high horse power forced induction vehicles. Using the an HPX MAF and 1000cc injectors we have tuned for over 550whp on the G35.
Osiris Tuner is a licensed based system. The purchase of Osiris Tuner includes one license that will be transferred to the first ECU that is flashed. This vehicle can then be flashed as many times as the user wants, but the flash will not work on any different vehicles.
Osiris Tuner does not include any base maps or eTunes, the user is expected to develop their own tune for their vehicle using the stock ROMS included in the software package. Paid technical support can be found through UpRev’s Pro Tuners or through purchasing eTunes. There is no tuning tech support with the purchase of Osiris Tuner.
Parameters that are supported in the ROM Editor include:
Idle RPM
Speed Limiter
Rev Limiter
DTC disable
AFR Targets
Fuel Compensation
MAF transfer function
Cranking Enrichment and Ignition Advance
Injector Latency
K Fuel Multiplier
Intake Temp
Calculated Load vs. RPM
Minimum Effective Injector Pulse Width
PM me with any questions and pricing structure!!
