Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Splitfire DIS-101 Direct Ignition Coil Packs Nissan 350Z / Infiniti G35 03-06
Old 11-26-2014, 02:53 PM
Ray@OCInfiniti's Avatar
Splitfire Super Direct Ignition System is a high performance ignition system.
The Splitfire direct ignition coil has an increased wire turn on coil, and high quality materials compared to the standard coil.
The difference of spark between Direct Ignition System and Standard system is very clear. This difference brings great advantage for sports driving. It helps complete combustion to improve combustion efficiency, and also increases power and torque. SplitFire Super Direct Ignition Systems are specifically designed for limited engine models, and they are all bolt-on type for easy installation.
The special circuit adopted for this unit helps to start engine at lower voltage. It provides the excellent starting performance even lower voltage. It also eliminates noise and RFI (Radio Frequency Interference) for audio equipment because plug wires were eliminated. Drastic improvement for ignition system! Excellent Power and Response! Feel the efficiency of the innovative ignition tuning!
For: G35 Coupe/Sedan 03-06, M35 06-07; Nissan 350Z 03-06 (Includes Roadster)
$540 Shipped to the 48 lower states, if CA resident add 8% tax
sergio@ocinfiniti.com
or call 7146508585 to place an order.
Allow 1-2 days for product to be shipped.
Old 07-28-2015, 09:15 PM
prjoker's Avatar
do u still have those coils????
Old 08-03-2015, 10:21 PM
prjoker's Avatar
rezendvous420
05-31-2020 01:26 PM
ClwMike
07-23-2015 12:55 PM
Blakelyg35
07-21-2015 12:49 PM
G35driver111
07-20-2015 05:51 PM
Quick Reply: Splitfire DIS-101 Direct Ignition Coil Packs Nissan 350Z / Infiniti G35 03-06
