AAM Competition S/R-Line Intake System!!!
Features:
Dyno proven up to 15 hp in S-Line configuration
Dyno proven up to 20 hp in R-Line configuration
2.75” 6061 Aluminum Tubing
Precision CNC S-LINE Tuning Insert
4-ply Silicone Couplers
Stainless Steel Clamps
Genuine High Flow K&N Air Filters
CAD Designed
Full detailed instructions available
Made in the USA
MSRP: $539.99
Sale Pricing: $499.99
Forum Price: PM me!
Flexibility, Tunability, Performance! The AAM Competition 370Z Intake System is the only adjustable intake system for the 370Z – giving you the option to maximize your vehicles performance depending on your vehicles current setup (stock, mildly modified, heavily modified).
Developed with upgradability in mind, the variable design provides flexibility in engine tuning. Stock or near stock 370Z/G37’s will use the intake in S-Line configuration. In S-Line configuration the intake can be installed on the vehicle without any other adjustments and provides a clean, easy to install 10-15 wheel horsepower gain. 370Z’s equipped with more bolt-on upgrades and engine tuning will use the intake in R-Line configuration. R-Line configuration provides maximum air-flow to the engine allowing for up to 20 horsepower gains when tuned.
S-Line Intake Configuration
AAM Competition designed the intake to use 2.75” aluminum tubing, mandrel bent for optimal flow. The system also features a carefully engineered MAF (Mass Airflow Sensor) insert called the S-Line Tuning Insert. By reverse engineering the OEM MAF sensor housing and after many hours of intense testing, AAM Competition determined the optimal shape and diameter for the S-Line Tuning Insert. The S-Line Tuning Insert affects the OEM ECU programming in a way that keeps everything within specifications for normal operation while taking advantage of smoother, less restrictive piping and filtering for impressive power gains.
R-Line Intake Configuration
For those wanting maximum power, simply remove the S-Line Tuning Insert and tune the car using aftermarket tuning software. Removing the S-Line Tuning Insert allows for maximum airflow to move unrestricted through the intake optimizing efficiency and performance.
All hardware and install instructions are included with the kit. Strong 4-ply silicone couplers ensure a snug fit, while allowing for engine movement and flex. The high flow air filters keep the air flow unrestricted, while efficiently protecting the engine from the elements.
CAD Designed
Made in the USA
MSRP: $539.99
Forum Price: PM me!
