Tires from Hell
on
Tires from Hell
Just Hit 5k miles on my 2008 EX35 in about 2 1/2 months. Here is the cliff notes version:
- Noticed a tire vibration when driving from dealership after delivery(dealership is 80miles from home) . Got home, found too much psi, adjusted psi next morning.
- Drove about 1000 miles before vibration became too noticeable. Took it into dealership, they rebalanced and rotated. Noticed no improvement on drive home.
- Took it back, they turned the rotors and rotated tires 180 degrees on wheel and rebalanced.
- Took it into local Nissan dealership who has road force machine and had them test/balance it. Rims good. Found excessive roadforce (>12lb) on 2 tires. They were 9lb, 10lb, 17lb, 26lb.
- Informed Infiniti about it. They needed to perform their own test, so took it in again, used their Lexus dealership's roadforce machine to test. Ordered 4 new tires under warranty.
- Went in again for get replacements put on, balanced and everything (5th trip into dealership)
- Life was good, right?.....WRONG!
- Put 2000 miles on new tires, hit a few potholes, drove though some down pours and heat spells, etc. Noticed steering wheel vibration return at 5000miles. Looked at wheels, saw missing weight (just sticky tape, no weights).
- Figured no biggie, will just take it into Nissan for roadforce. master tech calls me back to the bay to show that 1 tire is showing 27lb of roadforce and machine refuses to balance. WTF? Other are at 13lb, 17lb & 18lb WTF? These are worse than the old ones!
- Just wrote a long *** email to Infiniti dealership expressing frustration.
So I am at $120 out of pocket for roadforce balancing, 5 trips to dealership, 80 miles each way, for ~800 miles. They are out 4 tires, 4 free service appointments and have 1 unhappy customer in an EX that is 2 1/2 months old at 5000 miles.This is not cool.
Btw, the tires I have are the OEm Michelin 225/60R17, run them at 34psi cold.
Do you guys get vibration at the 70-74mph mark, specially noticeable if you hit 75mph and coast down to 70mph on a smooth road. some vibration in steering wheel and some coming though seat and shift lever?
There are some TSB regarding to steering rack vibration.... not sure if that's your case
www.infiniti-techinfo.com
