FS: G35 JDM Power Folding Mirrors
just to give a little insight. for the sedan ones you can just switch the bases because the angle of the holes on the bases are different. on the coupe the actual arms of the mirrors are angled differently and the bases are the same with the us version so switching the bases does not work. what i did is filled in the holes on the base and built up a little wall and drilled new holes so the mirrors are sitting at different angles. if you dont do this even with the mirrors maxed out they will be utterly useless.
for the folding function you just need to extend two additional wires to each mirror so you will need to drill a small hole in the door wire molex to run the wires.
