ARCH Industries POLY IMPUL SIDESKIRTS
#32
if the poly cracks, your car is screwed. it takes a lot of force to tear it... to crack it means you had to hit a sharp object that pierced right through it. The poly bumpers we offer are almost 5mm thick. most fiberglass kits out there barely hit 2mm and a good chunk of that is the gel coat if they even put that down. Poly is the way to go, leave the fiberglass stuff unless you DON'T daily drive your ride.
#37
The sideskirts will be shipped out to all paid orders when its complete. ETA is end of the month.
#39
#43
#45
